help needed. wheel bearing going bad.
Old Apr 25, 2015 | 11:40 PM
Hawkfan72487's Avatar
Member
Default help needed. wheel bearing going bad.
I have a 2006 cooper s and the passenger rear wheel bearing is making noise. It is a little loose and I bought what I thought was the correct wheel bearing/hub only to find that my wheel studs are larger than the holes for the wheel studs on the new hub. So my questions is this. How do I know which bearing/hub to get to replace my bad wheel bearing.
Old Apr 27, 2015 | 06:29 PM
PelicanParts.com's Avatar
Hi there,
This should be of some help for you. Let me know if you have any other questions.
-Luccia
Old May 3, 2015 | 02:02 AM
Member
Thank you. It was definitely tricky trying to get it figured out. My cooper s was made September of 06 so I needed the 14mm studs.
Hawkfan72487
May 21, 2015 12:04 PM
Tbov235
Apr 6, 2014 11:40 AM
blue ak mini
Sep 7, 2011 10:38 PM
jtkessler
Dec 11, 2010 08:05 PM
