help needed. wheel bearing going bad.
I have a 2006 cooper s and the passenger rear wheel bearing is making noise. It is a little loose and I bought what I thought was the correct wheel bearing/hub only to find that my wheel studs are larger than the holes for the wheel studs on the new hub. So my questions is this. How do I know which bearing/hub to get to replace my bad wheel bearing.
Thank you. It was definitely tricky trying to get it figured out. My cooper s was made September of 06 so I needed the 14mm studs.
| All times are GMT -5. The time now is 03:47 AM. |
