-   -   Help please.....newbie (https://minicooperforums.com/forum/2002-2006-mini-cooper-s-r53-12/help-please-newbie-3667/)
beth Oct 31, 2010 03:24 AM
Hi everyone. I'm now the proud owner of a cooper s :) I've only had her a few days and the passenger electric window has stopped working. Drivers side all ok. I tried the reset(which I think is door open, engine running, and hold window switch up for 10seconds) but hasn't solved it. Any ideas please? There is still the clicking relay sound when you try and undo the window.
bad venge Oct 31, 2010 04:35 PM
try the hit it just above the speaker reset ...
It normally works , if the motors OK
Black Magic Nov 2, 2010 11:13 AM
Sounds like the window lifter and or the motor is failing. I have replaced both sides on mine this past month. Drivers side just went out over the weekend.
To help you the EOM part numbers are:
Window Lifter: 51-33-7-039-451 Retail $168.90
Drive motor: 67-62-6-955-875 Retail: $110.27
The above part numbers are for the Left / Drivers side.
Cheers,
