Loosing anti freeze
HEY GUYS. I HAVE AN 06 ''S''. I'M LOOSING ANTI FREEZE. I CAN'T FIND A LEAK. WOULD RADIATOR SEALER CLOG THE INTERCOOLER?:cool:
Originally Posted by HANGMAN
(Post 16985)
good luck finding it. unless a mechanic recommends putting that stuff in it I wouldn't. |
I would not use radiator sealer. You need to track down the leak. For a 2002-2006 MINI Cooper S or 2005-2008 MINI Cooper S Convertibles, there are a couple main locations to check.
Coolant expansion tank. They will leak at the seam. Part # 17137529273 http://www.ecstuning.com/Search/SiteSearch/17137529273/ http://c1552172.r72.cf0.rackcdn.com/232905_x600.jpg Radiator at the top neck on the driver side. It will leak at the neck, have to replace the whole radiator, the neck is not sold separate. Or upgrade to Mi****moto version w/ lifetime warranty. Aluminum Radiator Part # 17117570489 http://www.ecstuning.com/Search/SiteSearch/17117570489/ http://c1552172.r72.cf0.rackcdn.com/438878_x600.jpg Also check the heater core which is near the foot well. Heater core: http://www.ecstuning.com/Search/64111497527/ http://c1552172.r72.cf0.rackcdn.com/76879_x600.jpg And don't forget the heater core kit: http://www.ecstuning.com/Search/64116910914/ES176630/ http://c1552172.r72.cf0.rackcdn.com/76810_x600.jpg Recommend the MINI OEM coolant and mix with distilled water. http://www.ecstuning.com/Search/82140031133/ES196253/ http://c1552172.r72.cf0.rackcdn.com/221464_x600.jpg Also check the thermostat neck on the driver side of the engine. Part # 11537596787KT We have a kit that has a new thermostat since it has that gasket and the hardware to install. http://www.ecstuning.com/Search/SiteSearch/11537596787Kt/ http://c1552172.r72.cf0.rackcdn.com/366122_x600.jpg Thanks and hope that helps. |
