MCS is creaking when starting from a stop
It only happens during the first 10-15 minutes of driving and it only does it when I'm starting from a stop and it isn't every time I start, maybe every couple starts. (It used to only do it when I was starting on a hill). It literally sounds like a creaking door that needs to be greased or something. Is this anything I need to worry about?
Thanks in advance
Thanks in advance
Sounds like rear suspension component. Upper rear strut mounts. One set for each side.
#10 rear shock mount foam bushing.
#10 Shock Mount - Rear 33526754123
http://www.ecstuning.com/Search/SiteSearch/33526754123/ES1981541/
These can make noises when worn and compressed over time.
Until its warms up. Check you rear brake calipers, pads etc , and if the emergency brake cables are fine. If your emergency brake cables are rusted it drags on the rear brakes, pads against rotors.
Emergency brake cables refresh kit. Part # 34406777400KT
http://www.ecstuning.com/Search/SiteSearch/34406777400KT/
