MCS thermostat removal/install w/ JCW airbox
MINI COOPER S (w/ JCW air box)
Thermostat & housing removal & installation JCW AIR FILTER BOX COVER REMOVAL · 6mm, loosen air inlet hose clamp · Lift hood seal up and out of way · Untuck battery terminal cables from side of box, may need to remove ziptie · Disconnect vacuum line at front of air box · #25 torx driver, loosen (2) screws at front of air box · Push air box back (about ˝”), lift up, disconnect two vacuum lines, unclip vacuum switch and set aside, remove air box DISCONNECT COMPUTER HARNESS CONNECTIONS · 10mm socket, remove bolt holding computer harness cable · Remove computer box cover · Slide t-handle connectors forward and rearward, respectively and lift up on plugs, set aside AIRSCOOP REMOVAL · Using screwdriver, disconnect air tube to air box bottom (push down on tab) · Wiggle air scoop up and out (rear tube up, lift up and get drain out, then pry clockwise to remove front of scoop – install reverse order) AIRBOX BOTTOM REMOVAL · Lift up 1-2”, box should be clear to remove (you’ll see 2 rubber grommets on the bottom that fit over two ˝” pegs) UNDO WIRING CLIPS AROUND T-STAT HOUSING · Using 3mm allen wrench, remove (2) screws holding down wiring plug directly about t-stat housing · Disconnect plug and set aside DISCONNECT IGNITION COIL WIRE · Slide red locking clip LEFT, disconnect wire from coil · Lift up on two retaining clips along cable, set aside REMOVE LOWER ENGINE SHIELD · Using Phillips screwdriver and 10mm socket, remove (2) screws and (3) bolts hold lower engine shield · Slide shield reward, set aside DRAIN COOLANT ***allow engine to cool sufficiently before removing*** · Place catch pan below lower radiator hose · Using channel locks, loosen hose clamp · Remove lower radiator hose (may need to use small screwdriver to free hose from fitting, be careful not to puncture hose with screwdriver) · Allow coolant to drain · Reattach lower radiator hose & clamp REINSTALL LOWER ENGINE SHIELD · Slide panel forward into place, align rear screw holes · Using Phillips screwdriver, reinstall (2) rear screws · Using 10mm socket, reinstall (3) front bolts (this order will allow for proper fit alignment of panel) T-STAT HOUSING REMOVAL / INSTALLATION · Using 10mm socket, remove (3) housing bolts · Remove t-stat housing · Clean up engine block surface (I used some 400grit sand paper) · Properly align t-stat and gasket in old/new housing (spring goes toward engine block) · Reinstall housing AND metal bracket · Torque appropriately (can’t remember value) REINSTALL REMAINING ITEMS IN REVERSE ORDER |
