-   -   Mini Cooper r53 Misfiring (https://minicooperforums.com/forum/2002-2006-mini-cooper-s-r53-12/mini-cooper-r53-misfiring-5135/)
gta18 Jan 3, 2012 06:48 PM
Anybody has a wiring diagram for the 2003 Mini Cooper r53?
Thanks!
JoeMc Jan 20, 2012 07:56 AM
Try This
Disconnect your battery terminal (negative) for about 5 minutes then reconnect. This should reset your ECU. It may run rough the first 2 - 3 times you start it while everything resets. If this doesn't fix it, find someone who has a code reader and get the code number. It sould like a bad plug wire to me. Nothing a wiring diagram will help with.
Joe Mc
