Modifications for 2005 Mini Cooper S
Hi, I have a 2005 Mini Cooper S. I have a budget of $1000 and am looking to increase the power significantly. I have seen several modifications come up repeatedly (pulley, exhaust,chip), but I was wondering what combination of modifications will work best in my budget. Could you recommend a list of modifications that would fit in budget? Also looking for specific part recommendations. Thanks
The Way Motor Works Pulley Package 15% pulley - Comes with belt, pulley, and colder plugs runs about 180.00
WMW Pulley Package - Way Motor Works
Do the one ball mod, a simple google or forum search will show you that . Easily done by a shop for 100.00 or less.
Ireland Engineering Adjustable Rear Sway Bar ~200
Ireland Engineering 22mm Adjustable Rear Sway Bar - Way Motor Works
Sprint Booster- will improve throttle response ~250
Sprint Booster Power Converter - Way Motor Works
Air Intake -I would Suggest buying one USED, there are a ton out there on the market used. run you about 100-150
Screamin Demon or MSD coil pack and wires .. Should run you about ~100-125 .
That should get you going pretty good, an also allow you to upgrade the handling to go with the increased power.
You can get all of this stuff and more from WAY MOTOR WORKS. They are a trusted vendor and very reliable.
Tommyvilla0527
Apr 29, 2017 12:05 PM
joey50
Nov 10, 2007 02:56 PM
