-   -   Noisey clutch (https://minicooperforums.com/forum/2002-2006-mini-cooper-s-r53-12/noisey-clutch-1367/)
hoggman1987 Sep 11, 2008 06:17 PM
Noisey clutch
I drive a 2002 cooper s.
When I am stopped and take off i more often then not hear a load noise from my clutch.
It is only when Iam going forward never in reverse. It sounds as if something is rubbing and it happens when my the clutch is about 2 inches off the floor. Is this a problem with the clutch and it needs to be replaced or is there a simple sollution that wont cost me a arm and a leg?
Cheers!
yuille36 Sep 12, 2008 04:58 AM
RE: Noisey clutch
I have that same problem, it doesn't occur all the time, but ocassionally. So, if you get any advice, drop me an email at yuille36@comcast.net
MINIofANNAPOLIS Sep 18, 2008 08:56 PM
RE: Noisey clutch
is it a rattling sound?
yuille36 Sep 19, 2008 05:47 AM
RE: Noisey clutch
NO, its more like a slight rubbing or grinding noise as if the clutch fork is rubbing slightly on the clutch disc. But it doesn't happen all the time just every so often.
ymperformance Oct 2, 2008 06:16 PM
RE: Noisey clutch
You need a dual mass flywheel!!! when you press the clutch the nosie goes away....
Jano Oct 22, 2008 03:43 PM
RE: Noisey clutch
I'm not sure if this is the same thing but I have kind of a whirring sound occassionally when I take off. Mostly when it's cold and only forward. My dealership is over 100 miles away so if anybody has any insight I would appreciate it.
yuille36 Oct 29, 2008 12:06 PM
RE: Noisey clutch
Yes, when I press in the clutch the noise does in fact go away.
So, you said that I need a dual mass flywheel?
What's the difference from a regular flywheel?
So, what is happening in my tranny with the clutch and flywheel, explain?
Yuzuki Nov 9, 2008 10:30 PM
RE: Noisey clutch
I have seen a different forum this is caused by oil dripping on the clutch plate. Not sure if it's true 100% or not. They said there isn't really anything you can do. But like I said I'm not sure if it's true. I have a 03 S and it does it every so often. [:'(]
yuille36 Nov 10, 2008 09:37 AM
RE: Noisey clutch
The question is how is oil getting on the flywheel or clutch disk?
Is the main bearing seal leaking?
gasmans_1979 Nov 10, 2008 10:55 PM
RE: Noisey clutch
usually if I use the clutch gently, that is to let it engage without to much foot feed I don't seem to notice the noise either. A new clutch was put in my 2006 s back in june. To say I am a little puzzled would be a understatement.
