Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Installing a CD Changer
Old May 19, 2005 | 05:38 PM
jnarva's Avatar
Default Installing a CD Changer
I am thinking of installing an after market CD changer and had heard that all Cooper S' w/ were prewired w/ the connector in RH rear. Does anyone knew where to look for this connector?
Old May 22, 2005 | 08:48 PM
1fstmini's Avatar
Default RE: Installing a CD Changer
I think its in the right panel b/c you mount the OEM changer on the lower right of the floor.....havent done one myself but ive seen pleanty at the shop. I can find out if you havent found it yet tomorrow when i get into work......also...if its the same as BMW, the connectors are different from the aftermarket DIN connector which you will then need a convertor connector to put in the changer which is available at any stereo shop. i havent had anyone ask to put an aftermarket one in a MC yet so i dont know if you have to splice the line to make it work.
abbynormal
Aug 30, 2010 07:40 PM
wkminidrver
Sep 13, 2008 12:30 PM
ronnie948
Sep 13, 2008 12:10 PM
datjams
Jun 8, 2007 11:42 AM
jnarva
May 22, 2005 08:48 PM
