| 1fstmini |
May 22, 2005 08:48 PM |
RE: Installing a CD Changer
I think its in the right panel b/c you mount the OEM changer on the lower right of the floor.....havent done one myself but ive seen pleanty at the shop. I can find out if you havent found it yet tomorrow when i get into work......also...if its the same as BMW, the connectors are different from the aftermarket DIN connector which you will then need a convertor connector to put in the changer which is available at any stereo shop. i havent had anyone ask to put an aftermarket one in a MC yet so i dont know if you have to splice the line to make it work.
