Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
No power from battery
Old Jan 30, 2025 | 03:42 PM
cmc's Avatar
cmc
Default No power from battery
Hello!
I've had problems with my minicooper 2012 clubman since buying it, most of them having to do with a constant battery drain, bad grounding wire, etc.
Because of the battery drain, I unhook red terminal of the battery every day, and I believe this has caused a new problem with the antitheft device in the car that triggers everytime power is lost, because now there is no power with the battery connected.
When I connect the black terminal to the engine, though there is power and the car does turn on, the anti-theft device does not trigger the sound of a relay firing(?).
I was wondering if anyone had any info on what this is or how I can fix it.
Thank you for reading and for any help.
Old Feb 26, 2026 | 03:53 AM
salted's Avatar
2019 Countryman S here! 27K miles and the only issue in 5 years is a dead battery. These are great cars!
snaptube vidmate
Beaglegirl
May 9, 2024 06:48 AM
AliasAlice
Jul 28, 2022 08:31 PM
geometrix
Feb 16, 2018 07:55 AM
glasspony
Jun 21, 2009 10:01 PM
