-   Audio/Visual Electronics (https://minicooperforums.com/forum/audio-visual-electronics-19/)
-   -   No power from battery (https://minicooperforums.com/forum/audio-visual-electronics-19/no-power-battery-14284/)
cmc Jan 30, 2025 03:42 PM
Hello!
I've had problems with my minicooper 2012 clubman since buying it, most of them having to do with a constant battery drain, bad grounding wire, etc.
Because of the battery drain, I unhook red terminal of the battery every day, and I believe this has caused a new problem with the antitheft device in the car that triggers everytime power is lost, because now there is no power with the battery connected.
When I connect the black terminal to the engine, though there is power and the car does turn on, the anti-theft device does not trigger the sound of a relay firing(?).
I was wondering if anyone had any info on what this is or how I can fix it.
Thank you for reading and for any help.
salted Feb 26, 2026 03:53 AM
2019 Countryman S here! 27K miles and the only issue in 5 years is a dead battery. These are great cars!
snaptube vidmate
