Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
subwoofers
Old Jan 27, 2009 | 06:16 PM
rkiller69's Avatar
Default subwoofers
would a sobwoofer look and sound nice in a mini cooper?
aftermarket subwoofer
Old Jan 27, 2009 | 06:30 PM
Default RE: subwoofers
Yes but unfortunately they take up most of the rear hatch area even for a small 10" sub
Old Jan 28, 2009 | 04:30 PM
rkiller69's Avatar
it would sick right?
plus ill get like and 8in or 6in
i dont put alot of stuff in my hatch i guess it would work
Old Jan 28, 2009 | 05:01 PM
Go with at least a 10 the others are not true woofers and response suffers .... Pioneer makes an ultra thin 10 I've been eyeing
Old Jan 28, 2009 | 06:14 PM
rkiller69's Avatar
can u gimme the website to the subs that you have been eyeing and where could i get them installed???
Old Jan 28, 2009 | 06:49 PM
http://www.pioneerelectronics.com/PU...-SW1001S2%7CS4
type in your zip code for nearest dealer
Old Feb 24, 2009 | 02:20 AM
shorty12's Avatar
Default subwoofers
aftermarket subwoofers sound pretty good inside of the minis i just recently put a 12" sub in mine if you don't mind giving up the whole trunk space then it's a pretty good way to go.
Old Feb 24, 2009 | 08:17 AM
  #8
With the pioneer 10 you can make a shallow box the depth of the trunk and make it flat to the lip , use a subwoofer grill to prevent damage when hauling
Old Jan 3, 2010 | 12:31 AM
  #9
ChiliCoop's Avatar
Old thread, but for those still searching for a subwoofer solution, this one looks pretty sweet. Would be interested in hearing from anyone who's installed one successfully, especially in the R57.
http://integralaudio.com/mini/mini-c...del-120sa.html
That Pioneer low profile 10" subwoofer may be the way to go though. They have an enclosure meant for under seat install that would likely fit nicely into the boot. Going to measure tomorrow.
http://www.pioneerelectronics.com/PU...10U.Shop?tab=D
Old Jan 3, 2010 | 08:49 AM
  #10
those would be a nice start , I thought about making a side mount box to allow the bottom to remain unmolested
