-   Detailing (https://minicooperforums.com/forum/detailing-28/)
-   -   Detailing tip of the week (https://minicooperforums.com/forum/detailing-28/detailing-tip-week-2811/)
SMARTWAX Jan 12, 2010 05:54 PM
Detailing tip of the week #1:
Apply quick detail spray after washing while drying to restore premium gloss. Shop www.smartwax.com for your detailing needs
SMARTWAX Jan 20, 2010 05:46 PM
Detailing tip of the week #2
for superior streak free windows, spray product sparingly on to window, work over entire surface then with a second towel buff away.
SMARTWAX Jan 27, 2010 05:43 PM
DETAILING TIP OF THE WEEK #3 - Always use lubricant or Smartdetail spray to clay, because soap will break down or deteroate the clay. When using lubricant or Smartdetail it will prolong clay life by conditioning the clay.
SMARTWAX Feb 18, 2010 12:59 PM
next tip is a maybe a lil of a common sense but not to many...
NEVER DRY ON HIGH HEAT YOUR MF TOWELS, OTHERWISE YOU WILL RUIN THE FIBER CAUSING IT TO CREATE SWIRLS ON YOUR PAINT, YOU WANT TO SET YOUR DRYER TO DELICATE OR JUST AIR DRY.
SMARTWAX Feb 25, 2010 02:31 PM
HERE IS ONE MAYBE ALOT KNOW BUT AT THE SAME TIME NOT SURE...
THE REAL PROCESS OF DETAILING A CAR CONSIST OF : WASH,CLAY, POLISH if needed, GLAZE if desired, SEALANT, WAX for your finishing touch.
SMARTWAX Mar 3, 2010 12:57 PM
IS ABOUT THAT TIME AGAIN.....
TIP OF THE WEEK: Maintianing your wheels finish while mazimizing shine is easy. Start by cleaning wheels first. Applying a quick coat of Smartwax RIMWAX
SMARTWAX Mar 17, 2010 01:30 PM
and this week's tip is:
Proper detailing towels will make any detailing job a breeze, SmartWax recommend high grade microfiber towels with 70/30 blend like our Monsters Towels 16x16, http://www.smartwax-usa.com/ProductD...de=MIC_1100_03
SMARTWAX Apr 1, 2010 12:54 PM
here is another...
Detailing tip of the week: when fully detailing the exterior of your car (wash,clay,seal,glaze,wax) you should be using 6-12 towels min. preferable double sided microfiber towels with silk trimming.
SMARTWAX Apr 14, 2010 01:52 PM
detailing tip of the week:
"for those that do car shows or just simply want to use no water to clean your rim & tires on the spot, we have a solution...use any citrus base product like carpet cleaner or smartcarpet blended with water on the rim & tire, wipe off with a microfiber towel to a perfect clean surface" apply more if needed. this process is good on any type of finishes.
http://www.smartwax-usa.com/ProductDetails...Code=SM_INC_103
SMARTWAX Apr 29, 2010 01:12 PM
GM FRIENDS! DETAILING TIP FOR A WINDY DAY "TO PREVENT FROM SCRATCHING YOUR PAINT WHILE TRYING TO REMOVE THE DUST FROM THE WIND, ALWAYS USE A QUICK DETAIL FOR A BETTER RESULT.
https://www.smartwax-usa.com/Product...ctCode=EXT_102
