-   Exterior (https://minicooperforums.com/forum/exterior-18/)
-   -   Cleaning black lower side sills (https://minicooperforums.com/forum/exterior-18/cleaning-black-lower-side-sills-1082/)
joe8553 May 15, 2008 10:52 AM
As I was waxing my Mini I tried not to get wax on the lower black body molding but failed. How does one clean the white streaks left on by the wax? Next time I will probably cover the molding as I wax the sheet metal. Thanks for your help!
bad venge May 16, 2008 07:18 PM
RE: Cleaning black lower side sills
I use 3M adhesive remover ... Others use Isopropyl Alchohol , others use WD-40... If you use WD you'll have to wash it down
http://www.showcardetailing.com/bw/ Try this to keep them like new
Adam May 17, 2008 09:10 AM
Absolutely the best thing to use:
http://www.jcwhitney.com/wcsstore/jc...0764G_SW_1.jpg
bad venge May 17, 2008 06:08 PM
Have you TRIED the Black Wow ??? I used to use Back to Black and the Black wow smokes it ...
WHITE07 Nov 16, 2008 05:38 AM
Bacl to black and others just cover the wax. I used MR Clean magic eraser .It worked like a charm. Also the roof rails . The magic eraser worked well then a little back to black .
John
