-   Exterior (https://minicooperforums.com/forum/exterior-18/)
-   -   door handle switch (https://minicooperforums.com/forum/exterior-18/door-handle-switch-1680/)
donaldb Jan 17, 2009 06:45 AM
door handle switch
has anyone changed out the door handles for these
http://www.outmotoring.com/mini-coop...r_handles.html
how does the key lock work? do you take your old ones out and install in the new handles?
bad venge Jan 17, 2009 08:26 AM
RE: door handle switch
I changed out a set for a club member it was pretty much bolt/unbolt , the lock mechanisms are easily removed and replaced
donaldb Jan 17, 2009 08:29 AM
do you just need to remove the interior door panel to gain access and remove the old handle?
bad venge Jan 17, 2009 09:04 AM
yes ...
