Exterior Talk about your rims, body kits, and other exterior mods here.
driving lights
Old 01-01-2009 | 12:45 PM
donaldb's Avatar
Default driving lights
Where is the best place to get the brackets for driving lights? I found an oem kit somewhere that had the lights and brackets that was like 600 bucks. I would like to have driving lights but not that bad
Old 01-01-2009 | 03:22 PM
Old 01-01-2009 | 04:40 PM
donaldb's Avatar
Default RE: driving lights
thanks for the good info
ours is a 2006 S convertible
Old 01-01-2009 | 05:08 PM
I'd get either set from outmotoring the ones on the hood or the ones below to mount , then chose the set of lights you want
Old 01-01-2009 | 06:55 PM
donaldb's Avatar
In my Mini where the window,fog light,ect switches are, there is a blank spot in the cluster. can you get a switch that matches these or close to control driving lights?
I am not sure how the factory driving lights are controlled, if they would be like the fog lights, they shut off when you use high beam, and do not care for the idea that if I get the oem kit and mount them at home I still need to take it to the dealer so they can tell the car they have been installed, so I think the way for me to go, would be an after market kit and would like to mount the switch where I have an opening in the switch cluster. I am going to order something from outmotoring today or tomorrow, just not sure what yet
thanks
Old 01-01-2009 | 07:28 PM
The toggle switches can be purchased from the dealer.The part # is 64113452459
Another way is they sell a wireless 12v switch , it's a remote deal no switch to mount ...
http://www.oznium.com/remote-switch
Old 01-01-2009 | 07:56 PM
donaldb's Avatar
Wow
that remote switch deal is kool. got it headed this way
thanks
  #8
Old 01-01-2009 | 08:04 PM
If you plan on adding others things get the 4 channel one ... I used mine up already
alikhann
04-07-2012 09:43 AM
wooden indian
06-24-2010 11:48 AM
styyy
03-29-2010 10:26 AM
clnconcpts
07-30-2008 11:48 PM
mgg1500
10-01-2006 12:35 AM
