-   Exterior (https://minicooperforums.com/forum/exterior-18/)
-   -   driving lights (https://minicooperforums.com/forum/exterior-18/driving-lights-1632/)
donaldb Jan 1, 2009 11:45 AM
driving lights
Where is the best place to get the brackets for driving lights? I found an oem kit somewhere that had the lights and brackets that was like 600 bucks. I would like to have driving lights but not that bad
bad venge Jan 1, 2009 02:22 PM
RE: driving lights
You don't say what year ... Aaron is AWESOME to deal with ...
http://www.outmotoring.com/mini-coop..._brackets.html
http://www.outmotoring.com/mini-coop...light-kit.html
http://www.outmotoring.com/mini-coop...-brackets.html
http://www.outmotoring.com/mini-coop...light_kit.html
Others :
http://new.minimania.com/web/STSearc..._Inventory.cfm
http://www.minicarparts.net/ProductL...&CurPage=1
donaldb Jan 1, 2009 03:40 PM
RE: driving lights
thanks for the good info
ours is a 2006 S convertible
bad venge Jan 1, 2009 04:08 PM
RE: driving lights
I'd get either set from outmotoring the ones on the hood or the ones below to mount , then chose the set of lights you want
donaldb Jan 1, 2009 05:55 PM
RE: driving lights
In my Mini where the window,fog light,ect switches are, there is a blank spot in the cluster. can you get a switch that matches these or close to control driving lights?
I am not sure how the factory driving lights are controlled, if they would be like the fog lights, they shut off when you use high beam, and do not care for the idea that if I get the oem kit and mount them at home I still need to take it to the dealer so they can tell the car they have been installed, so I think the way for me to go, would be an after market kit and would like to mount the switch where I have an opening in the switch cluster. I am going to order something from outmotoring today or tomorrow, just not sure what yet
thanks
bad venge Jan 1, 2009 06:28 PM
RE: driving lights
The toggle switches can be purchased from the dealer.The part # is 64113452459
Another way is they sell a wireless 12v switch , it's a remote deal no switch to mount ...
http://www.oznium.com/remote-switch
donaldb Jan 1, 2009 06:56 PM
RE: driving lights
Wow
that remote switch deal is kool. got it headed this way
thanks
bad venge Jan 1, 2009 07:04 PM
RE: driving lights
If you plan on adding others things get the 4 channel one ... I used mine up already
