Exterior Talk about your rims, body kits, and other exterior mods here.
My Cooper Light is Fogged, Need Advice Please
Old Aug 2, 2011 | 01:05 PM
TheoBrown's Avatar
Default My Cooper Light is Fogged, Need Advice Please
Hey everyone.
I hope I've posted this in the correct forum section. If not, please forgive me. I couldn't find the troubleshooting/problems section.
Anyways, I own a 05 Mini Cooper, of which the headlight (driver side) has gotten foggy. It's certainly not as transparent as the passenger side light. At first I wasn't sure why one was foggy and the other wasn't, but then I took a closer look at the foggy light and noticed a small crack on the outside casing. I believe this crack has allowed moisture to enter the light. I've heard of people restoring their headlights with special DIY kits, but I've decided to take the route of simply replacing the light with an aftermarket light from an online store. I found two sites that I particularly liked, but I'm unsure of whether or not they are legitimate businesses. Furthermore, I don't want to fall prey to a scam. Has anyone purchased from either of these sites and can verify that they are a legitimate business? The following parts match the OEM number of the one I need. Thanks in advance.
Mini Cooper Headlight > AutoLightCenter.com
or
Halogen; Without Headlamp Washer Headlight Assembly Composite
Old Aug 2, 2011 | 04:59 PM
most of these do not match them 100% so I'd recomend getting both , as these are not stock
you can try baking the bad one at lowest temp in an oven (remove bulbs /metal/latches ect dry them and seal the crack
Yardley
Nov 26, 2012 08:18 AM
snerkler
Oct 12, 2009 02:32 AM
jimrios
Sep 22, 2009 09:37 PM
loyroman
Aug 17, 2009 02:17 AM
myPeppy
Nov 6, 2008 11:44 PM
