Clutch Masters 2014+ MINI Cooper 2.0L Turbo and 1.5L Turbo Clutch Kits and Flywheels
Old Oct 28, 2019 | 11:49 AM
ClutchMasters's Avatar
Former Sponsor
Default Clutch Masters 2014+ MINI Cooper 2.0L Turbo and 1.5L Turbo Clutch Kits and Flywheels
Hello there MINI Cooper Forum enthusiasts! We wanted to let all of you 3rd Gen MINI Cooper owners know about our new clutch and flywheel options for the 2.0L and 1.5L turbo engines! We now have available ready for purchase are several performance clutch kit options as well as lightweight aluminum and steel flywheel kits for the 2014+ Mini Cooper, Cooper S, Countryman, Clubman, and John Cooper Works models using the 2.0L B48 and 1.5L B38 turbo engines. Right now Clutch Masters is the only company offering aftermarket replacement clutch kits and flywheels for the 3rd Gen MINI Coopers so we wanted to give you MINI enthusiasts a little rundown of the options we have available!
1.5L Turbo:
Clutch Masters offers conversion kits that eliminate the undersized 228mm clutch and dual-mass flywheel. The conversion kits are offered as a complete clutch kit and can be paired with either a Clutch Masters lightweight aluminum flywheel or lightweight steel flywheel.
2.0L Turbo:
Clutch Masters offers a clutch kit that will work with the OE flywheel or one of our lightweight aluminum or steel flywheels specifically engineered for the Mini. Because of tight tolerances and the design of the OE Dual Mass Flywheel, only rigid discs are able to be used with the OE flywheel and may not be desirable for a street driven car. The Clutch Masters Aluminum Flywheel comes in at 14lbs and the steel flywheel weighs 25lbs.
The Clutch Masters single disc offerings include the FX100, FX250, FX300, FX350, and FX400 to suit a specific driving style and torque capacity needs. Utilizing the highest quality friction materials combined with Clutch Masters Hi-Leverage pressure plate technology we are able to significantly increase clamping force with no unnecessary increase in pedal pressure. Our kits will include a release bearing, clutch fork, alignment tool, and mounting hardware.
- The FX100 utilizes a dampened steel back Organic lined disc. The FX100 is engineered for heavy-duty street use. It is specifically designed for extended wear and additional clamping force for the enthusiast who has added an exhaust or air intake system and tune. It features only slightly increased pedal pressure, longer life than stock clutch, and normal clutch feel during engagement and disengagement for a very smooth operation.
- The FX250 utilizes a dampened steel back disc with a hybrid combination of friction materials including Formula Button on one side and a heavy-duty Organic friction lining on the other (basically a combination of the FX350 and the FX100 materials). This clutch is designed for the street enthusiast or weekend racer who plans to abuse their vehicle on an occasional basis and have a spirited driving style.
- The FX300 utilizes a dampened steel back segmented kevlar friction lined disc. This clutch is designed for the ultimate street enthusiast running significantly more boost then factory, and/or has had head work done to the engine. The FX300 features only slightly increased pedal pressure, long life disc and positive engagement. The FX300 is only recommended for the street and not for the track. Minimum 500 Required break-in miles.
- The FX350 has a higher holding capacity than a segmented Kevlar lining (FX300) without compromising the street friendly characteristic Clutch Masters is known for. Engineered for street use with a focus on being able to handle racing on the weekend, this clutch is perfect for the street enthusiast or weekend racer who plans to abuse their vehicle on an occasional basis and has a spirited driving style.
- The FX400 is available in two disc styles, an 8-puck full ceramic disc design or a segmented 6-puck disc. The full ceramic disc creates a quick and rapid engagement and maintains minimal chatter due to the marcel cushion between the disc linings, this disc is designed for street driven vehicles. The 6-puck ceramic paddle design creates a quick and rapid engagement as well as clutch chatter that may not be ideal for street driven vehicles and is meant solely for track cars. The full-face 8-puck ceramic disc design creates a quick and rapid engagement and yet maintains minimal chatter due to the marcel cushion between the disc linings. This disc is designed for street driven vehicles and is designed for outstanding holding capacity, and rapid heat dissipation.
The FX500 is designed with the race track in mind. This disc and the ceramic pucks are designed for outstanding holding capacity and rapid heat dissipation. The FX500 ceramic paddle design creates a quick and rapid engagement as well as clutch chatter and is not recommended for the street. The solid hub, or rigid disc, engages and disengages instantly. If you are building your MINI to compete on the race track and that is the sole purpose of the vehicle, then the FX500 is a great option.
With dampened and rigid clutch disc options as well as a lightweight aluminum and steel flywheel, we have a setup that will work for street and/or track driven cars.
Quick Specs:
  • Clutch kits and Flywheels are Designed and Manufactured in the USA
  • FX100, FX250, FX300, FX350, FX400, and FX500 kits available
  • Lightweight Aluminum Flywheel, 14 lbs, Type 3 Hard Anodized
  • Lightweight Steel Flywheel, 25 lbs, Black Oxide Treated
  • 1.5L Turbo conversion kits include clutch kit and flywheel to upgrade from the undersized 228mm clutch and eliminate the dual mass flywheel
  • Clutch kits units will include a release bearing, clutch fork, alignment tool, and mounting hardware.
Fitment:
  • 2014-2019 MINI Cooper S 2.0L Turbo
  • 2016-2019 MINI Cooper Clubman
  • 2017-2019 MINI Cooper Countryman
  • **Includes all JCW models as well**
Part Numbers:
2.0L Turbo Clutch Kits and Flywheels1.5L Turbo Conversion Clutch Kits w/ FlywheelsFor any questions or inquiries please feel free to shoot us over an email to andrew@clutchmasters.com or call us at 909-877-6800.
Of course we also have clutch kits and flywheels for the 1st and 2nd Gen MINI Coopers as well so if you are in need of a new clutch for your 1.6L supercharged or turbo MINI, we have options for those as well!
Feb 2, 2018 04:11 PM
sneedspeed
Aug 22, 2016 09:04 AM
Jan 20, 2014 08:56 AM
dcsweet
Jun 21, 2012 12:01 PM
TimNC
Oct 19, 2011 03:48 PM
