Old Jul 21, 2017 | 07:46 AM
  #91
NEW Turner Motorsport MINI Poly Tow Straps
With the prohibition of the steel tow ring in multiple racing series, a new more close-quarter racing friendly solution was needed. Introducing the Turner Motorsport Poly Tow Straps!
These polyester tow straps are the best tow strap available for the modern MINI chassis. Using a heavy-duty, chemical-resistant polyester strap webbed around a stainless steel stud. This design allows for tow hooks to grab onto it without hitting your bumper.
If you are racing your MINI, a Turner Motorsport Poly Tow Strap is a must have track accessory.
Fits:
R50-R59 MINI Cooper /S/JCW (2002-2015)
Click HERE For your R50-R59 MINI Cooper 2002-2015
Fits:
F54-F57 MINI Cooper (Gen 3)
R60 MINI Countryman/ R61 MINI Paceman
*The 75mm size tends to work best with the F55+ Bumpers because the mount is further recessed. The best practice is to measure the distance from the tow hook mounting threads to the outside of the bumper cover.
Click HERE For your Gen 3 F54-F57 MINI Cooper & Gen 2 MINI Countryman/Paceman
We build it. You could win it!
For years, ECS Tuning has been your trusted source for original, aftermarket, and performance parts for your European car. Our team of enthusiasts have worked hard to build the best catalog in the industry, providing you with the knowledge and expertise to keep your car looking, sounding, and performing great year after year.
This year, we are partnering with BILSTEIN to give back to our valued customers. To show our appreciation we are giving away a new Audi A3 customized with all the goodies. All you have to do to enter is spend $50 at ECSTuning.com. Furthermore, each multiple of $50 you spend brings an additional entry; so for example if you spend $500, you get 10 entries.
Click HERE for all the details on our A3 Sweepstakes
Old Jul 26, 2017 | 10:20 AM
  #92
Godspeed Coilovers Now Available For Your MINI Cooper
Ride height too tall? Looking for the perfect set of coilovers? This premium mid-level budget coilover system from Godspeed will get you there.
Two levels of coilover from the Mono-SS (pink color) to the Mono Maxx (red color), these coilovers are built for aggressive street and track driving. The Mono-SS includes 16 levels of dampening compared to the Mono Maxx which takes it to a higher level of 40 ways of dampening.
All systems contain dual front upper pillow-ball cushioned adjustable camber plates, giving you the extra adjustment you will need.
Fits: MINI 2002+
See Red Lines in ad for fitment.
Click HERE For your MINI Cooper 2002+
Old Jul 28, 2017 | 04:22 PM
  #93
F54-F57 Forge Motorsport - New Products
Forge Motorsport has developed a reputation for premium performance upgrades that address often times overlooked areas of your vehicle.
ECS offers an extensive range of some of the most impressive Forge products for your MINI Cooper.
Need a quick change shorter shifter throw on the long OEM set up? Get the first on the market with all metal construction from Forge.
Forge Coilovers feature 32 levels of damping adjustment with shock length adjustment, so you can go from slightly lowered to very low.
Forge Ahead
Fits:
F54-F57 MINI Cooper /S/JCW 2014+
Old Aug 2, 2017 | 10:52 AM
  #94
Solo-Werks Coilovers For Your MINI Cooper - New Product
Ride height too tall? Looking for the perfect set of coilovers? This premium entry level, budget-minded coilover system from Solo-Werks will get you there.
S1 coilovers are fully height adjustable with fixed rate shock damping. Featuring progressive elastomer bump stops and black spring perches with a double lock ring design, these coilovers are built for aggressive street and track driving.
All Solo-Werks S1 coilovers come with a 3 year limited warranty.
Fits:
R50-R53 MINI Cooper /S/JCW (2002-2008
MINI High Pressure Fuel Pump Replacement - Best Price NEW!
We have included all the must need parts direct from the manufacturer for your Turbo MINI high-pressure fuel pump repairs.
This HPFP (High-Pressure Fuel Pump) is the main pressure behind the direct injection engine and is located on the side of the engine head. The HPFP is located on driver's side of the engine and assists the fuels system to deliver the higher fuel line pressure. Sometimes you will get a false start or a check engine light that contributes to loss of fuel line pressure.
Resolve those multiple issues and put the power back into your engine.
Uh-Oh, Now What!
Fits:
R55 MINI Clubman S / JCW (2008+)
R56 MINI Cooper S /JCW (2007+)
R57 MINI Cooper Convertible S / JCW (2009+)
R58 MINI Coupe' S/JCW (2012+)
R59 MINI Roadster S/JCW (2012+)
Euro Impulse Weighted Shift ***** For Your MINI
Shift some excitement into your MINI with a Euro Impulse weighted aluminum shift ****, available at ECS Tuning!
With a weight of just under 300 grams, this solid aluminum custom weighted shift **** allows for easier shifts, and improves the overall interior look of your MINI.
Fits:
R50-R61
MINI 6 speed manual transmission
Old Aug 7, 2017 | 12:36 PM
  #95
Raceseng Shift ***** For Your MINI Cooper - New Product
Easy to install
Fits like the factory
Many options/colors to choose from
Fits:
Gen 1- Gen 3 MINI Cooper 2002+
Click HERE For your MINI Cooper, select year and model to see fitment
Wagner Tuning MINI Cooper Intercoolers R55/R56/R57 S (N14)
Wagner engineers have increased the intercooler core size and efficiency, as well as improved the end tank design to remove any OEM bottlenecks. This is resulting in increased flow rating and charge cooling properties.
These intercoolers come with a black finish aluminum with a "Tube Fin" Intercooler core which includes turbulators in a stepped design.
ECS now offers a Wagner Tuning intercooler from Germany for your Gen 2 N14-powered Cooper S, giving you the largest horse power/torque gains without a ECU tune.
Fits:
R55 MINI Clubman S (2008-2010)
R56 MINI Cooper S (2007-2010)
R57 MINI Cooper Convertible S (2009-2010)
Wagner Tuning Intercoolers | MINI R55-R61 (N18)
ECS now offers a Wagner Tuning intercooler from Germany for your Gen 2 N18-powered Cooper S/JCW, giving you the largest horse power / torque gains without a ECU tune.
Fits:
R55 MINI Clubman S/JCW (2011+)
R56 MINI Cooper S/JCW (2011+)
R57 MINI Cooper Convertible S/JCW (2011+)
R60 MINI Countryman S/SX(ALL4)/JCW (2011+)
R61 MINI Paceman S/SX(ALL4)/JCW (2013+)
Wagner Tuning MINI F56 Cooper S Intercoolers (B46/B48)
Wagner engineers have increased the intercooler core size and efficiency, as well as improved the end tank design to remove any OEM bottlenecks. This results in increased flow rating and charge cooling properties.
ECS now offers a Wagner Tuning intercooler from Germany for your Gen 3 2.0L Turbo-powered Cooper S/JCW, giving you the largest horse power / torque gains without a ECU tune.
Fits:
F56 MINI Cooper S (2014+)
Dinan Gen 3 MINI Cooper S Axle-Back Exhaust PRICE DROP
Dinan engineers designed the F56/F55 MINI Cooper S exhaust to improve exhaust flow by reducing back pressure, resulting in increased power output. Includes a great sporty sound that is civilized when you want it to be, and pleasantly aggressive under hard acceleration. Like all Dinan exhausts, their F56/F55 Free Flow Exhaust is engineered to combat low-RPM drone so the cabin of the vehicle is still intimate and not drowned in an excessively loud tone.
Known for early 2002 MINI performance, now back with 2014+ MINI products!
Not just an exhaust
Fits:
F55, F56 MINI Cooper S (2014+)
Old Aug 11, 2017 | 03:32 PM
  #96
MINI Countryman JCW Aero Body Kits 52% Off
ECS presents truly stunning, authentic performance styling from the most hallowed MINI tuner on earth with the John Cooper Works Aero Kit. All of this Genuine JCW kit - at an unprecedented value.
Primed and ready to paint for the Countryman this kit include a front bumper with trim, rear bumper with trim, and side rocker panel/side skirts with trim.
This kit completely transforms the impression of your car while retaining the reserved design aesthetic characteristic of all genuine MINI products.
Includes all install hardware in the kit.
Add some flare to your MINI
Fits:
R60 MINI Countryman S/SX(All4)/JCW (2011-2016)
Click HERE For your MINI Countryman
MINI P3 Multi-Gauge - Performance Visualized
Before your next stop light liftoff, add a space age digital system monitor to your cockpit. P3 Gauges Vent Integrated Digital Interface is a plug-and-play data display that "fits like factory," in easy view of the pilot seat.
Pop it on and plug it into your car's onboard diagnostic connector. Then scroll through critical vehicle parameters and monitor manifold pressure, system temperatures, and other vital stats.
No programming, coding, cutting, or splicing.
Fits:
R50-R53 MINI Cooper /S/JCW (02-08')
R55-R59 MINI Cooper /S/JCW (2007+)
R60-R61 MINI Cooper /S/JCW (2011+)
F55-F57 MINI Cooper /S/JCW (2014+)
BMC Air filters and Air Intakes
High performance carbon fiber intake
Lifetime high-flow air filter that's a direct replacement
Fits:
Gen 1 - Gen 3 MINIs 2002-2017
Countryman and Paceman Wheel Options
These sets of Alzor, NM Engineering, AC Schnitzer, AVANT GARDE, D-FORCE, Dinan, fifteen52, and VMR wheels will not only change the look of your vehicle, but also capture the attention of others. The multi-classic to modern styles wheels will give your car a sleek appearance that will keep people looking as you pass.
Designed to bolt right up to your car, these wheels fit without any hassle.
Of course, if you want to achieve an extreme look, don't forget to check out our large assortment of ECS Tuning wheel spacers and lug bolts.
Fits:
R60 MINI Countryman /S/SX(All4)/JCW 2011+
R61 MINI Paceman /S/SX(All4)/JCW 2013+
Old Aug 21, 2017 | 09:58 AM
  #97
Genuine MINI Wheels Clearance Up To 51% Off MSRP
Bald tires? Curbed wheels?
Start the season right with some clean new wheels and fresh rubber. Everything you need to mount on the car and drive - while skipping the trip to the tire shop!
Some of the most famous styles of MINI genuine wheels from individual 16" R90's to full sets of 18" R113's redlines that are ready to bolt-on.
Fits:
R50-R59 MINI Cooper '02-'15
Click HERE For your MINI Clearance Wheels
MINI Cooper Ziza Flash Sale 25% off / Free shipping
Transform your complete interior in minutes with new LED interior bulbs from Ziza and its 25% off /free shipping just for today!
Fits:
Your MINI
Click HERE For your MINI Cooper Master kits on Sale
All other kits:
Dorman Replacement Parts
Great price and value direct replacement parts for your MINI Cooper
Free Shipping on most parts.
Fits:
Click HERE For Dorman parts for your MINI Cooper
Old Aug 24, 2017 | 01:47 PM
  #98
GoBadges Now @ ECS with full and New Updated Catalog!
Since 2010, GoBadges has focused on helping people personalize their cars while designing a business and brand that is rewarding and enjoyable for all. It has always been about better design, a bit of fun, and entering into the unknown.
Fits:
Your MINI
Click HERE For your MINI Parts
Click HERE For your Dome Badges
Click HERE For your Dome Badge Holders, Plates, and Plate Badgebars
Click HERE For your 3D Badges
Click HERE For your 3D Badge Holders, Plates, and Plate Badgebars
Click HERE For your GO Graphics
Click HERE For your Interior
Click HERE For your Exterior
Click HERE For your Wheels
Schwaben MINI Timing Chain Kit Tools NEW
Today's modern engines were made with complex tools that only dealerships seem to have on hand. This forces one to take their vehicle to a dealer in order to get routine service. With these new tools from Schwaben, you can do this service yourself. Whether you need to do up your brake calipers, remove lug bolts and trim, ignition coils, or tighten your timing belt, Buam Tools has the tool for the job. These high-quality and long lasting tools will do the job right the first time, giving you more time to enjoy your vehicle where it belongs, on the road.
All Schwaben tools and tool kits are manufactured under strict quality control standards, designed to give you years of trouble-free service.
Fits:
Gen 2 N12, N14, and N16 Engines
R55-R61 MINI Cooper /S/JCW '07-'16
Click HERE For Schwaben MINI Cooper Timing Tool Kit
ST Savings For Your Gen 1 MINI
ST Performance Suspensions is having a sale, making their already highly competitive pricing even more appealing. This superb offer applies to all sway bars, coilovers, and lowering springs. Along with the savings from ST, ECS Tuning is also offering gift cards up to $50 and free shipping on select products.
Featuring low-friction, pressure-resistant housings and chrome-plated piston rods for maximum longevity, ST X series suspensions provide more predictable, stable handling dynamics and height adjustability across a wide range.
Fits:
R50-R53 MINI Cooper /S/JCW (2002-2008)
Click HERE For MINI Cooper
ST Savings For Your R56 MINI Cooper
Fits:
R56 MINI Cooper S/JCW (2007-2013)
Old Aug 28, 2017 | 04:31 PM
  #99
Up to 15% off ECS Wheel Spacers: 3 Days Only!! MINI
Sale Ends 8/30/17
Spacers for your racer. ECS Tuning lets you tweak your stance - or swagger down the road with a larger 30mm spacer.
Choose from our huge inventory of hub centric spacers in thicknesses sure to match your car, your wheels, and your shopping budget.
All ECS MINI spacers are aluminum, and are black anodized for corrosion protection. Kits come with correct-length black lug bolts for a complete package.
Fits:
Your MINI
Click HERE For your MINI Wheel Spacers, then select your MINI from the left-hand side.
Old Aug 31, 2017 | 08:06 AM
  #100
Sneed4Speed Now @ ECS with updated Catalog
Sneed4Speed started out creating performance parts for the track and street driven MINI. Their parts were tested and proven on their very own track at multiple speedways. From aerodynamic parts to braking kits and everything in between. Now you can get all the Sneed4Speed products at ECS Tuning!
Free shipping on most parts!
Fits:
Your MINI
KONI Rebate up to $70 Off
When it comes to your suspension, a trusted name from the aftermarket is one of the best ways to give your vehicle a great ride and a great look. A leader in suspension for over 50 years, Koni has all of the necessary parts to lower your car without much sacrifice in ride quality.
Fits:
Your MINI
Click HERE For KONI Rebate
Free Redline Water Wetter with Redline Oil service kit: Limited time
Using our premium oil service kits ensure that your MINI gets the best service possible, and allows you to extend the change intervals of your engine oil.
If you are serious about maintaining your car, then our ECS Tuning Premium Oil Service Kits are for you.
For a limited time only, receive a FREE bottle of Redline Water Wetter with any Assembled by ECS Redline Oil Service Kit.
Reduces coolant temperatures by as much as 30°F
Fits:
Your MINI
