ECS Tuning ZippeeShade Now @ ECS with updated Catalog ZippeeShade Sunroof Sunshades are developed exclusively to fit your MINI's sunroof. Newly redesigned with UV-resistant black fabric on one side and reflective silver on the other side. Once installed, you can simply leave the shade in place and open your sunroof without fear of it blowing away. Easy install. Fits: Your MINI https://e345d83943122432250a-6a9cf06...B_25011_01.jpg Click HERE For your MINI Parts -------------------------------------------------------------------------- -------------------------------------------------------------------------- Dinan Dinantonic Elite New This high-end controller was designed from the beginning to be easily installed and even easier to use. It plugs into a sensor and uses the factory DME to re-map boost, timing, and fuel maps. Changes can be made via Bluetooth, allowing you to use your smartphone to turn boost and other parameters up for max performance or down for conservative driving. Fits: Your MINI https://e345d83943122432250a-6a9cf06...P_24989_01.jpg Click HERE For Dinan Dinantronic Elite ----------------------------------------------------------- Liqui-Moly Molygen Engine Oil 5w-40 ONLY AT ECS Tuning Liqui-Moly Molygen Engine Oil • Lower fuel consumption, Longer engine life. • Molecular friction control – 15% lower friction coefficient to reduce wear by up to 30%. • Meets BMW/MINI LL-01 Fits: Your MINI https://e345d83943122432250a-6a9cf06...R_25021_01.jpg Click HERE For MINI Cooper --------------- |
ECS Tuning N18 Engine Performance Module Tuner From NM Engineering NEW! These boost controllers were designed from the beginning to be easily installed and even easier to use. It plugs into a sensor and uses the factory DME to re-map boost, timing, and fuel maps. Changes on the NM module can be done with a switch on the module itself. Up to 28Hp 36lb/ft gain on NM Engineering module, making this respected MINI tuning brand a no-brainer. A great leader in MINI performance parts, continuing in the Gen 3 MINI platform! Go Faster! Fits: N18 Engine R55-R61 MINI Cooper S (2011-2016) R55-R61 MINI Cooper JCW (2013-2016) May work with the N14 engine and older Gen 2 MINIs also! Testing in progress! https://e345d83943122432250a-6a9cf06...R_25039_01.jpg Click HERE For your MINI N18 Engine Power Module -------------------------------------------------------------------------- -------------------------------------------------------------------------- MINI Cooper Rear Wiper Delete Plug - Glass Version You decided to drop the rear wiper for a clean look but aren't sure what to put in the hole it leaves behind. Homemade fixes made from bottle caps and super glue look... homemade. We have the answer. Our rear wiper arm delete cover is an exact fit matte black trim plug with transparent sealing surround. Push it into the hole vacated by the wiper arm for a factory-like look that seals water tight. We have a kit that also contains the RTV silcone needed below for an easy complete install. Simple and Clean Fit: R56 MINI Cooper /S/JCW '07-'13 https://e345d83943122432250a-6a9cf06...P_25010_01.jpg Click HERE For ECS MINI Cooper wiper delete - glass version ----------------------------------------------------------- aFe New Products! Advanced FLOW engineering (aFe) is a manufacturer of automotive cold air intake systems, performance air filters, fluid filters, intake manifolds turbochargers, programmers, throttle body spacers and exhaust systems. aFe was founded in 1999 and is headquartered in Corona, California, USA. Fits: Your MINI https://e345d83943122432250a-6a9cf06...P_25025_01.jpg Click HERE For MINI Cooper --------------- On Sale! Assembled By ECS Cooling Refresh R53 R52 S 15% off and free shipping Don’t let an aging cooling system keep you from enjoying your MINI the way it was meant to be driven. Proper function is maintained by regularly replacing coolant, housings, and hoses in order to prevent leaks or corrosion that cause overheating and dreaded head-gasket issues. Make sure your cooling system is doing its job by performing the proper maintenance repairs with our assembled kits. 9/18-9/20 3 days only! Fits: R52/R53 MINI Cooper S/JCW (2002-2008) https://e345d83943122432250a-6a9cf06...S_25040_01.jpg Click HERE For Gen 1 MINI Cooper S/JCW --------------- Partstoberfest - Cooling Kits Up To 15% OFF! Don’t let an aging cooling system keep you from enjoying your MINI the way it was meant to be driven. Proper function is maintained by regularly replacing coolant, housings, and hoses in order to prevent leaks or corrosion that cause overheating and dreaded head-gasket issues. Make sure your cooling system is doing its job by performing the proper maintenance repairs with our assembled kits. Sale ends 9/20/17 Fits: R55-R59 MINI Cooper /S/JCW '07-'15 https://e345d83943122432250a-6a9cf06...P_25041_01.jpg Click HERE For MINI Cooper --------------- |
From NOW until 9/27/2017 Save up to 25% on Ziza Lighting Products! Click HERE for your on-sale MINI Cooper Ziza Lighting http://0c6ae9a232ed4697ae13-6a9cf06e...S_23626_01.gif Click HERE to save up to 25% on 2002-2006 R50 MINI Cooper Ziza Lighting Products Click HERE to save up to 25% on 2005-2008 R52 MINI Cooper Convertible Ziza Lighting Products Click HERE to save up to 25% on 2002-2006 R53 MINI Cooper Ziza Lighting Products Click HERE to save up to 25% on 2007-2010 R56 MINI Cooper Ziza Lighting Products Click HERE to save up to 25% on 2011+ R56 MINI Cooper Ziza Lighting Products Click HERE to save up to 25% on 2008-2015 R55 MINI Clubman Ziza Lighting Products Click HERE to save up to 25% on 2009-2016 R57 MINI Cooper Convertible Ziza Lighting Products Click HERE to save up to 25% on 2012-2015 R58 MINI Coupe Ziza Lighting Products Click HERE to save up to 25% on 2012-2015 R59 MINI Roadster Ziza Lighting Products Click HERE to save up to 25% on 2011+ R60 MINI Countryman Ziza Lighting Products Click HERE to save up to 25% on 2013+ R61 MINI Paceman Ziza Lighting Products Click HERE to save up to 25% on 2014+ F56 MINI Cooper (2 Door) Ziza Lighting Products Click HERE to save up to 25% on 2015+ F55 MINI Cooper (4 Door) Ziza Lighting Products Click HERE to save up to 25% on 2017+ F54 MINI Clubman Ziza Lighting Products Click HERE to save up to 25% on 2016+ F57 MINI Cooper Convertible Ziza Lighting Products Click HERE to save up to 25% on your Audi Ziza Lighting Products Click HERE for your on-sale BMW Ziza Lighting Click HERE for your MINI Ziza LED and more lighting sale Click HERE for your Mercedes Ziza Lighting Click HERE for your Porsche Ziza Lighting Click HERE for your Volkswagen Ziza Lighting |
ECS Tuning CTS Turbo 25% Off! CTS Turbo has been dedicated to manufacturing performance parts for enthusiasts by enthusiasts since its inception. CTS Turbo is part of the Partstoberfest Sale for MINI Coopers at ECS! Take advantage of 25% off on their full line below. On Sale until 10/3/17 Fitment: R56 MINI Cooper S '07-'10/JCW '09-'12 R55 MINI Clubman S '08-'10/JCW'09-'12 R57 MINI Cooper Convertible S '09-'10/JCW '09-'12 R58 MINI Coupe' JCW '12 R59 MINI Roadster JCW '12 https://e345d83943122432250a-6a9cf06...R_23272_01.jpg Click HERE For all MINI Cooper CTS turbo parts 25% Off and Free Shipping! =========================================== =========================================== ECS Magnetic Drain Plugs 15% Off & Liqui Moly Oil Service kits 15% Off While changing your own oil gives you the confidence of knowing your vehicle and how to address its basic needs, using inappropriate parts and fluids will soon prove to be counterproductive and damaging. On Sale until 9/30/17 Fitment: All MINIs https://e345d83943122432250a-6a9cf06...S_25116_01.jpg https://cimg7.ibsrv.net/gimg/www.nor...cc164a05a8.png Click HERE For all MINI Cooper ECS Magnetic Drain Plugs/Liqui Moly 15% off! |
ECS Tuning Kohlefaser Luft-Technik Intake System - MINI R55-R61 15% OFF & $50 ECS Gift Card & Free Shipping! Months of tireless dedication and passion have resulted in a highly effective carbon fiber induction system, one that effortlessly weaves beauty with engineering rigor into one complete package that not only looks good, but is real world tested with the performance that is second to none. If you accept nothing but the best, this is the only complete carbon fiber air induction system for you! On Sale until 10/4/17 Save Now! Fits: R55-R61 MINI Cooper S/JCW ('07-16) https://e345d83943122432250a-6a9cf06...S_22834_01.jpg Click HERE For all ECS CF intake +$50GC and Free Shipping! |
ECS Tuning MINI R55-R59 Turbo : Frankenturbo Upgrade Revive your engine with a performance turbo. Use this as a bolt-on repair option for a failed turbo, or as a direct-fit performance upgrade. The FrankenTurbo F21M hybrid turbo gives you the option of running the turbo upgrade on your stock tune or upgrading your tune for a more powerful experience. Use it alone or as part of a complete performance upgrade. It's alive! 10% off Frankenturbo thru 10/31 Fits: R55-R59 MINI Cooper S/JCW ('07-'15) https://e345d83943122432250a-6a9cf06...R_22358_01.gif Click HERE For Frakenturbo 10% Off with Free Shipping! ========================================== |
ECS Tuning Agency Now At ECS Tuning For Your MINI From producing the first full Titanium Exhaust for your MINI to carbon fiber trim to set your MINI apart, Agency Power is ready to help make your car a bit more special. Fits: Your MINI, please select MINI on the left-hand side after clicking through. https://e345d83943122432250a-6a9cf06...S_25205_01.jpg Click HERE For all Agency Power, some with Free Shipping! ========================================== |
ECS Tuning SACHS Performance Clutches and Suspension Now At ECS Tuning For Your MINI SACHS performance clutches and suspension are trusted by manufacturers in the European and Asian markets for a reason! Equip your MINI with SACHS and you will see why. Fits: Your MINI, please select MINI on the left-hand side after clicking through. https://e345d83943122432250a-6a9cf06...S_25204_01.jpg Click HERE For all Sachs and Sach Performance ========================================== Canton Racing Products For Your MINI R52/R53 Time to take out those ugly factory expansion tanks and bring some shine to your MINI's engine bay with aluminum Coolant and Power Steering expansion tanks from Canton Racing Products. Free shipping also! Fits: R52 MINI Cooper Convertible S / JCW 2005-2008 R53 MINI Cooper S / JCW 2002-2008 https://e345d83943122432250a-6a9cf06...S_23611_01.jpg Click HERE For all CANTON Racing & Free Shipping! |
| All times are GMT -5. The time now is 03:11 AM. |
