Old Oct 25, 2017 | 04:43 PM
  #111
AST & MOTON Suspension Now Available
Thanks to an extensive racing pedigree, with experience in GT, 24 Hours of Le Mans, Touring Car Championships, and many other demanding racing arenas, MOTON Suspension for your MINI is the most highly developed and race proven setup available.
If you are looking for a more street drivable setup with the same standard of quality, AST lowering springs or coilovers are just what you need! With the same development strategy, but designed for less aggressive applications, you can experience a more performance-oriented look and feel without being excessive.
Now Available!
Fits
R50-F57 MINI Cooper 2002-2017+ ( Gen1-Gen3 )
**Most MINI Cooper coverage than most any other suspension brand.**
Click HERE For AST Suspension / Lowering springs with Free Shipping!
Click HERE For MOTON Suspension with Free Shipping!
Old Oct 27, 2017 | 09:21 AM
  #112
PowerFlex Bushings 15% off Now through Oct 30th
Sharpened handling. Increased agility. Tactile responsiveness. A feeling of being one with car and road. Replacing stock bushings with Powerflex polyurethane components will deliver all that and more.
ECS is proud to present the Powerflex brand of performance bushings. Powerflex is a world-renowned name in high-performance products, and they manufacture an array of quality suspension and chassis components.
From subframe mounts to control arm and sway bar bushings and more, nothing overpowers the Powerflex catalog and their reputation for durability and quality.
Fits:
Gen 1 R50-R53 MINI Cooper 2002-2008
Click HERE For your R50-R53 MINI Cooper Parts
Fits:
Gen 2 R56 MINI Cooper+ 2007+
Click HERE For your R56+ MINI Cooper Parts
Fits:
Gen 2 R60 Countryman/ R61 MINI paceman 2011+
Click HERE For your MINI Countryman Parts
Fits:
Gen 3 F56+ MINI Cooper 2014+
Click HERE For your Gen 3 F54-F57 MINI Cooper Parts
Old Nov 7, 2017 | 12:20 PM
  #113
Back in stock! Molygen from Liqui-Moly
The eery, green, somewhat mesmerizing glow... LIQUI MOLY Molygen uses revolutionary molecular friction control to protect your precious MINI Cooper! Exclusively available in the United States right here at ECS.
Also includes Liqui Moly UV flashlight! And also for a short time 10% off assembly kit!
Now Available!
Fits
Click HERE Molygen with Free Shipping!
In stock Valeo Dual Mass to Single Mass Conversion!
Convert your heavy and sluggish dual-mass flywheel to a Valeo Single Mass flywheel for your 6-speed MINI and feel the throttle response and revs benefit from lighter weight and better grip!
Fits:
R53 R52 MINI Cooper S / JCW (2002-2008
Click HERE For Valeo Conversion kits with Free Shipping!
In stock R50-R53 MINI Cooper Genuine MINI Valve Cover!
Is your MINI Valve Cover cracked and leaking? Are the bolts unsightly and corroded?
If that sounds like your engine, then it is time to clean it up with the Genuine MINI Valve Cover!
This new valve cover comes complete with the MINI logo, a new oil cap, all new hardware, gasket, and spark plug tube seals, making for a quick and easy installation.
To make things even easier, the kit comes completely assembled with the gaskets in place and the hardware installed.
Fits:
R50-R53 MINI Cooper /S/JCW (2002-2008)
Click HERE For Gen 1 MINI Valve covers with Free Shipping!
In stock R55-R59 MINI Cooper S/JCW N14 Valve Cover Kits!
A damaged valve cover can cause oil leaks, vacuum leaks, driveability problems, and even a check engine light. Additionally, cracks and warping can result in very poor performance unbecoming of any MINI.
The MINI Gen2 R55-R59 N14 engine valve cover is prone to damage over time. For this part, an aftermarket replacement is not an option. Thankfully, ECS supplies Genuine OEM MINI Valve Cover replacements for your car!
Included in the kits is all necessary parts from a basic to professional-level installation to restore your MINI.
Fits:
R56 MINI Cooper S (2007-2010) / JCW (2009-2012)
R55 MINI Clubman S (2008-2010) / JCW (2009-2012)
R57 MINI Cooper Convertible S (2009-2010) / JCW (2009-2012)
R58 MINI Coupe' JCW (2012)
R59 MINI Roadster JCW (2012)
Click HERE For Gen 2 N14 Turbo Engine MINI Valve covers with Free Shipping!
In stock R55-R59 MINI Cooper S/JCW N18 Valve Cover Kits!
The MINI Gen2 R55-R59 N18 engine valve cover is prone to damage over time. For this part, an aftermarket replacement is not an option. Thankfully, ECS supplies Genuine OEM MINI Valve Cover replacements for your car!
Fits:
R55-R59 MINI Cooper S/JCW (2011-2015)
R60-R61 MINI Countryman/Paceman S/SX/JCW (2011-2016)
Click HERE For Gen 2 N18 Turbo Engine MINI Valve covers with Free Shipping!
Old Nov 14, 2017 | 03:56 PM
  #114
New Dinan JCW Dinantronics Elite Performance Tuner
This high-end controller was designed from the beginning to be easily installed and even easier to use. It plugs into a sensor and uses the factory DME to re-map boost, timing, and fuel maps. Changes can be made via Bluetooth, allowing you to use your smartphone to turn boost and other parameters up for max performance or down for conservative driving. Control via the App on your smart phone.
Up to 58Hp and 88lb/ft gain with just this high tech module!
Dinan® products are warranted for the remaining term of the vehicle manufacturer's new car limited warranty which is up to 4 years
Now Available!
Fits:
F54-F57 MINI Cooper /S/JCW (2014+)
Click HERE For Dinan Elite Tuner and Other Dinan items with Free Shipping!
Maxton Design For Your MINI R55-R59
This Maxton Design front splitter, side skirt diffuser, and rear splitters will give your vehicle a performance/motorsport look in a matter of minutes. These pieces are made of durable ABS plastic and also includes all installation instructions and hardware needed for a quick install. They come in two finishes to fit your needs from a standard textured black to a high gloss jet black.
Set yourself apart from other MINIs with these rare body design extensions!
Fitment:
R56 MINI Cooper '07-'10
R55 MINI Clubman '08-'10
R57 MINI Cooper Convertible '09-'10
Click HERE For Maxton with Free Shipping!
Fitment:
R56 MINI Cooper S/JCW '07+
R55 MINI Clubman S/JCW '08+
R57 MINI Cooper Convertible S/JCW '09+
R58 MINI Coupe'S/JCW '12+
R59 MINI Roadster S/JCW '12+
Forge Motorsport Top Models
Forge Motorsport has developed a reputation for premium performance upgrades that address oftentimes overlooked areas of your vehicle.
ECS offers an extensive range of some of the most impressive Forge products for your Gen 2 & Gen 3 MINI.
The Alloy Power Assisted Steering Fluid Tank is a stunning piece, dressing up your engine bay while increasing the durability and longevity of the unit.
The stock rubber hoses on the MINI can often split, swell, and break over time. Forge offers chemical and corrosion-resistant Silicone Intake Hoses, available in Red, Black, and Blue.
Fitment:
R56 MINI Cooper S (2007-2010) JCW (2009-2012)
R55 MINI Clubman S (2008-2010) JCW (2009-2012)
R57 MINI Cooper Convertible S (2009-2010) JCW (2009-2012)
R59 MINI Roadster JCW (2012)*
Click HERE For Forge Motorsport with Free Shipping!
Fits:
F54-F57 MINI Cooper /S/JCW '14+
Old Nov 20, 2017 | 01:36 PM
  #115
NEW XKGLOW Make It Glow
Underglow is back in style! With interior and exterior lighting options easily controlled from your smartphone, XKGLOW lighting will help you stand out and express yourself.
Click HERE For lighting and other options !
Old Dec 4, 2017 | 12:22 PM
  #116
Milltek 10% OFF LEAP NEW Carbon Fiber CTS Turbo Sale!
Milltek Sport Exhaust Systems 10% Off and Free shipping!
Performance to blow your mind, not your ears! Improve performance and your vehicles sound with this cat-back exhaust system from Milltek.
Fits:
R50-F57 MINI Cooper 2002+
Click HERE for MINI Cooper Milltek Exhausts and select your year/model on the left-hand side after you click through
LEAP (aka LEAP Works) Now at ECS Tuning
Born from an enthusiast idea, LEAP provides Spoiler Extensions for your MINI that add an aggressive, yet unique, style to the profile and portrait of your European hot hatchback.
Now with the full line or molded (FRP) wings and scoops as well as a Full Carbon Fiber line. ONLY at ECS Tuning!
Fits:
R50-F56 MINI Coopers 2002+
Click HERE for your MINI Cooper and select your year/model on the left-hand side after you click through
CTS Turbo Sale Up to 20% Off For Your MINI Cooper
All your Turbo needs for your MINI are here from CTS Turbo. Get your MINI up to speed with everything boost, on sale now!
Fitment:
R56 MINI Cooper S '07-'10/JCW '09-'12
R55 MINI Clubman S '08-'10/JCW'09-'12
R57 MINI Cooper Convertible S '09-'10/JCW '09-'12
R58 MINI Coupe' JCW '12
R59 MINI Roadster JCW '12
Click HERE for Huge MINI Cooper Sale
Old Dec 7, 2017 | 02:16 PM
  #117
ECS Essentials For Your Gen 1-Gen 3 MINI Cooper 2002+ !
It all starts with the essentials - Do it right, or do it twice.
ECS Essentials are a special blend of drivetrain and styling upgrades designed to fine-tune and enhance the performance of your MINI.
The ECS Tow Hook/Plate Mount kit lets you use a front plate without the need of drilling into the bumper to mount the front plate. Improve pedal feel with Exact-Fit Stainless Steel Lines and enhance overall wheel appearance by upgrading to an ECS wheel bolts.
Build it better, build it stronger, build it with ECS.
Fits:
R50 MINI Cooper 2002-2006
R53 MINI Cooper S/JCW 2002-2006
R52 MINI Cooper Convertible /S/JCW 2005-2008
Click HERE for Gen 1 MINIs
Fits:
R55 MINI Clubman /S/JCW (2008-2015)
R56 MINI Cooper /S/JCW (2007-2013)
R57 MINI Cooper Convertible /S/JCW (2009-2015)
R58 MINI Coupe' /S/JCW (2012-2015)
R59 MINI Roadster /S/JCW (2012-2015)
Click HERE for Gen 2 MINIs
Fits:
Click HERE for Gen 3 MINIs
Up To 15% Off ECS Assembled R50-F57 2002+ !
Whether it is preventative maintenance or upgrading your MINI for performance, Assembled by ECS Kits are just what you need to tackle any job and keep your MINI happy.
Fits:
R53 MINI Cooper S (2002-2006)
R52 MINI Cooper Convertible S (2002-2008)
Click HERE for R52/R53 MINI Cooper Sale
Fitment:
R56 MINI Cooper S/JCW (2007-2013)
R55 MINI Clubman S/JCW (2008-2015)
R57 MINI Cooper Convertible S/JCW (2009-2015)
R58 MINI Coupe' S/JCW (2012-2015)
R59 MINI Roadster S/JCW (2012-2015)
Click HERE for R55-R59 MINI Cooper Sale
Fits:
R60 MINI Countryman /S/SX(ALL4) (2011+)
R61 MINI Paceman /S/SX(ALL4) (2013+)
Click HERE for R60/R61 MINI Cooper Sale
Fits:
F55 MINI Cooper S 2015+
F56 MINI Cooper S/JCW 2014+
F57 MINI Cooper Convertible S/JCW 2016+
F54 MINI Clubman S/ All4/JCW 2016+
Click HERE for F54-F57 MINI Cooper Sale
Old Dec 12, 2017 | 10:53 AM
  #118
NM Engineering 10% Off and Free shipping!
Do you want to give your MINI something special this year? NM Engineering products are all 10% OFF!
Fits:
Click HERE for MINI Cooper NM products and select your year/model on the left-hand side after you click through
AST / Moton Suspension Now at ECS Tuning and 10% Off
Now Available!
Fits
Maxton Design 20% Off For Your MINI Cooper
Fitment:
Gen 2 MINIs R56-R59 2007+
New Clinched Fender Flares For Your MINI Cooper
Clinched manufactures their fender flares out of high quality, impact-resistant ABS plastic, the same material OE bumpers are made of. This makes them very strong as well as lightweight. These fender flares are designed to be universal so they can be installed on many makes and models with minor customization. They can either be blended with the body of your car or left with exposed rivets and edges.
Clinched Flares are installed with rivets and bolts so you will need to drill and cut your original fenders in order to install on your vehicle. Use a heat gun (or a hair dryer) to heat up the flares and mold them into place to follow the factory body lines. The flares are very pliable which is what sets them apart from fiberglass flares.
Fitment:
ALL MINIs.
Click HERE for MINI Cooper Fender Flares
Old Dec 15, 2017 | 03:38 PM
  #119
Forge 10% Off and Free shipping!
Fits:
Click HERE for MINI Cooper Forge Motorsport products and select your year/model on the left-hand side after you click through
Dinan 10% Off and Free Shipping
Fits
F54-F60 MINI Cooper 2014+ ( Gen3 )
Click HERE For Dinan with Free Shipping!
Old Dec 19, 2017 | 04:46 PM
  #120
Shark Injector For Your R52-R53 MINI Cooper S/JCW 2002-2008!
You've heard it all before - “Good, cheap, or fast: pick two.” It's time to forget all of that.
The Good – Shark Injector software is dyno-tuned by BMW expert Jim Conforti, designed to preserve driveability & prevent damage.
The Fast – Raises the rev limit and improves mid-range torque & high-RPM horsepower. Plug & play push-button installation in 30 minutes or less.
The Cheap – Dyno-proven double-digit gains in horsepower & torque, priced far less than other modifications.
25% Off thru 12.21.17
Fits:
R52 MINI Cooper Convertible S (2005-2008)
