ECS Tuning If you are replacing your brake pads and rotors an important, yet often overlooked step is replacing brake system hardware. If your brake rotor set screws are showing signs of corrosion, a failed attempt at removing may result in a screw that needs to be drilled out.Utilizes T50 internal torx bit fitting which is the same as the Genuine MINI part! Our ECS Stainless Steel Brake Rotor Set Screws were designed, engineered, tested and quality inspected by our Research and Development team in our Wadsworth, Ohio facility. We strive for the highest level of precision and quality through leading-edge product development technology including FARO laser scanning for reverse engineering and quality inspection, SolidWorks 3D CAD modeling, rapid prototyping utilizing our in-house 3D printer, and rigorous long term product testing. https://c1552172.ssl.cf0.rackcdn.com/1720911_x800.webp https://c1552172.ssl.cf0.rackcdn.com/1720915_x800.webp "Click HERE for the MINI Cooper Stainless Steel Rotor Screws" Fits: 2002-2015 R50-R59 MINI Coopers ----------------------------------- ----------------------------------- Save money over MINI parts! Many other MINI brands on Sale up to 60% off!!! NM Engineering, Akebono, Cat Cams, HT, Hengst, Meyle, ALZOR Wheels, Teckniform Wheels, Clutch Masters, Forge Motorsport, M7 Speed, ALTA, Bav Auto, ECS Tuning, Bremmen Parts, K&N, AEM, FTP Motorsport, JM Turbo Coopers, SCHRICK, URO, Valeo, and Many other! Vinstar LED Lights, Bosch, and PSB Poly Bushings added to the sale!! https://ecsmedia.ecstuning.com/holiday_topper.jpg Fits: MINI 2002+ "Click HERE for the MINI Cooper Holiday Sale " ----------------------------------------------------------------------- ----------------------------------------------------------------------- |
ECS Tuning We have selected handfuls of products that we need out of our inventory to make room for bigger and better things. We have reduced their price until they are GONE. Deals like this go quick, so act soon or risk missing out. Limited time, limited stock, huge savings. https://ecsmedia.ecstuning.com/clearance_header.jpg "Click HERE for the MINI Cooper Clearance" Other Makes Below!! "Click HERE for the BMW Clearance" "Click HERE for the VW Clearance" "Click HERE for the Audi Clearance" ----------------------------------- ----------------------------------- |
ECS Tuning MINI Cooper Garbino Parts Japan MINIs are not known for their subtlety, which is something Garbino relied on when they developed their product line of body kits, flares, and other visual modifications that are big in Japan. Their exclusive partnership with us offers MINI owners like yourself the unique opportunity to jump on these race-inspired parts from some of the world's most renowned MINI racing experts. Check Your Fitments, please select your MINI from the left-hand side after you click through. Select parts now "in stock" while they last. http://ecsmedia.ecstuning.com/Mini_N...W_27013_01.jpg Click HERE to shop the Garbino ---------------------------------------------------------------------------------- |
ECS Tuning Save money over MINI parts! Milltek Sport and Many other MINI brands on Sale up to 60% off!!! Limited time, huge savings. Milltek Sport Exhaust, Clutch Master, JM Turbo Coopers, EBC, and many others on sale. https://c1521972.ssl.cf0.rackcdn.com...4947_22597.jpg "Click HERE for the MINI Cooper Sale" ----------------------------------- ----------------------------------- |
MINI High Pressure Fuel Pump Replacement - Back in Stock! We have included all the must need parts direct from the manufacturer for your Turbo MINI high-pressure fuel pump repairs. This HPFP (High-Pressure Fuel Pump) is the main pressure behind the direct injection engine and is located on the side of the engine head. The HPFP is located on driver's side of the engine and assists the fuels system to deliver the higher fuel line pressure. Sometimes you will get a false start or a check engine light that contributes to loss of fuel line pressure. Resolve those multiple issues and put the power back into your engine. **Now we have OEM supplier HPFP, the same supplier for MINI just no MINI logo on the box. Save $$$$** Uh-Oh, Now What! Fits: R55 MINI Clubman S / JCW (2008+) R56 MINI Cooper S /JCW (2007+) R57 MINI Cooper Convertible S / JCW (2009+) R58 MINI Coupe' S/JCW (2012+) R59 MINI Roadster S/JCW (2012+) R60 MINI Countryman S/S ALL4/JCW (2012+) R61 MINI Paceman S/S ALL4/JCW (2012+) https://e345d83943122432250a-6a9cf06...R_22527_01.jpg Click HERE For your MINI Cooper |
ECS Tuning Save money over MINI parts! Milltek Sport and Many other MINI brands on Sale up to 60% off!!! Limited time, huge savings. Milltek Sport Exhaust, Powerflex Clutch, Master, EBC, ECS, Dinan, Bilstein, Bavarian Auto, Bremmen Parts, and many others on sale. https://ecsmedia.ecstuning.com/PARTS...R_GRADIENT.png "Click HERE for the MINI Cooper Sale" ----------------------------------- ----------------------------------- ECS Tuning Located above the license plate on the trunk, these come in chrome or black (upgrade from factory), include the lights and lens just like the factory while including upgraded rubber sealed grip design with button. Plug and play! If you have a painted unit you will just transfer the old painted outside part to the new one with some small pliers to remove and install the new portion of the part. https://c1552172.ssl.cf0.rackcdn.com/1775808_x800.webp https://c1552172.ssl.cf0.rackcdn.com/387870_x800.webp Fits: 2007-2015 R56/R57/R58/R59 MINI Cooper /S/JCW "Click HERE for the MINI Cooper Bremmen Parts Trunk Lid Grips" Upgrade the stock lights to Ziza LEDs: https://c1552172.ssl.cf0.rackcdn.com/281331_x800.webp "Click HERE for the MINI Cooper Bremmen Parts Trunk Lid Grips Ziza LEDS" ----------------------------------- ----------------------------------- |
ECS Tuning Lift your MINI Cooper or European Car the safe way with this all in one system. Comes with the correct Jack Pad adaptor for MINI and other select Makes. RennStand is the first and only vehicle safety stand with usable height adjustment that allows you to put your jack and safety stand at the same point under your vehicle Rennen means RACE in German. The patented RennStand is revolutionary because it solves the problem of jacking and supporting in the right spot. It allows jacking and supporting using interchangeable jack pads designed for the vehicle. It’s easy, sets up in seconds and it is safer for the vehicle and the operator. It can be used with most floor jacks having a lift saddle of 3 inches in diameter or larger. The RennStand is rated for 3 tons and can extend to more than 16 inches. https://c1552172.ssl.cf0.rackcdn.com/1746968_x800.webp https://c1552172.ssl.cf0.rackcdn.com/1829616_x800.webp https://c1552172.ssl.cf0.rackcdn.com/1829615_x800.webp "Click HERE for the MINI Cooper Rennstand Jack Stand" ------------------------------------------------------------------------------------- DIY Video / install Video ------------------------------------------------------------------------------------- Also for all other European Makes such as BMW, Audi, Mercedes-Benz, Porsche, and VW (Volkswagen). https://c1552172.ssl.cf0.rackcdn.com/1746968_x800.webp "Click HERE for the BMW, Audi, Mercedes-Benz, Porsche, and VW (Volkswagen)" ----------------------------------- ----------------------------------- |
ECS Tuning Rare and no longer available from MINI is the factory (MC40) JCW Sport Gauges. 82940015951 OEM Part. This Gauge Holder is now back to life and in carbon fiber! Mounts in the center console of the original factory gauges pods that were a factory part on the special edition 2004 MINI Cooper S MC40. This is just the panel to hold the VDO style OEM gauges. Comes in carbon fiber with gloss coat. Great for adding those factory style gauges such as Oil Pressure and Voltage. Can hold two VDO style gauges. For VDO Gauges Use : One of each Part number 310-106 and 332-103 Sensor 323-055 or oem 82940004581 and washer noted on part. For replacement upgrade over the factory trim. If installing without factory kit Aux installed, you will need to wire your own harness and plugs. This can also be used as an upgrade for the stock black factory holder. https://c1552172.ssl.cf0.rackcdn.com/1734733_x800.webp https://c1552172.ssl.cf0.rackcdn.com/1820498_x800.webp https://c1552172.ssl.cf0.rackcdn.com/1820501_x800.webp "Click HERE for the MINI Cooper ECS JCW Sport Aux Gauges " "Click HERE for the Sensor 323-055" "Click HERE for the VDO Oil Temp" "Click HERE for the VDO Voltmeter" ----------------------------------- ----------------------------------- |
More Kevlar Belt Options! ECS Red Kevlar accessory Belts are both an aesthetic improvement and a performance alternative to a traditional belt. ECS Tuning Performance Kevlar reinforced belts give you that extra piece of mind! Kevlar reinforced belts experience less elongation over time minimizing the amount of belt adjustment needed as well as offering a higher shock and impact resistance compared to OEM style belts. https://c1552172.ssl.cf0.rackcdn.com/1617354_x800.webp Fits: Select 2002+ MINI Coopers "Click HERE for the MINI Cooper Kevlar Reinforced Serpentine Belts/Drive Belts " ----------------------------------------------------------------------- ----------------------------------------------------------------------- |
Finally Car Play Retrofits that don't require flashes! These will also not delete after software updates at the MINI dealer! Plug & Play interface to add Apple CarPlay and Android Auto to your factory infotainment system! These are piggybacks that give you the upgrade, here are the breakdowns and what unit to use. https://www.ecstuning.com/b-bremmen-...-sound_system/ https://c1552172.ssl.cf0.rackcdn.com/1751309_x800.webp CCC - This has the original MINI Navigation Screen R55/R56/R57 MINI Coopers 2007-2010 With CCC Navigation or 6.5" Factory Center Display Screen https://www.mini2.com/attachments/img_4415-jpg.279135/ CIC - This has the original LCI MINI Navigation Screen R55/R56/R57/R58/R59/R60/R61 MINI Coopers 2011-2016 With CiC Navigation or 6.5" Factory Center Display Screen. These MINI can have the Screen for MINI connected but no factory Navigation. So you have the screen but no Compass Icon. With our Carplay unit you will have Google Navigation. https://s3.motoringfile.com/wp-conte...78_highRes.jpg https://images.hgmsites.net/hug/2011...00318481_h.jpg NBT EVO - has the larger controller ( watch as people like to do the factory wider screen upgrade, so it looks like its this) https://0.rc.xiniu.com/g3/M00/53/F5/...ZQOdGxg078.jpg NBT - has the little controller ( watch as people like to do the factory wider screen upgrade) https://0.rc.xiniu.com/g3/M00/53/F5/...V4RkrZ0915.jpg Fits: Select 2007+ MINI Coopers "Click HERE for the MINI Cooper Carplay Andriod Units " ----------------------------------------------------------------------- ----------------------------------------------------------------------- |
