Old May 26, 2023 | 03:41 PM
  #341
More New Parts Added!
Performance Dry and Oiled Drop in Air Filters. Proper air intake flow will help your engine breathe better, improving power through the power band and improving fuel economy.
Higher flow than stock paper filters, this reusable filter will show an increase in performance immediately. An easy performance modification that is a direct replacement for your OEM filter.
Fits 2007+ R55-R61 MINI Cooper S/JCW (Not for JCW Tuning kits)
"Click HERE for the MINI Cooper ECS Drop in Performance filters Parts "
"Click HERE for the MINI Cooper K&N / ECS Drop in Performance filters Oil recharge kit "
Old Jun 6, 2023 | 03:56 PM
  #342
This valve cover solves two problems, either a check engine light code or an oily leaking top portion of the valve cover. Painted exterior without MINI wings logo, replaces your damaged or cracked valve cover. Keeping engine oil in and dirt out!
Now fix both PCV and cracked valve cover while upgrading to a high temp aluminum painted valve cover in RED, Orange, or Silver!!
OEM Design.
Fits 2007+ R55-R61 MINI Cooper/S/JCW
"Click HERE for the MINI Cooper Bremmen Parts Metal Valve Covers "
We even have plastic aftermarket valve covers for the 2014+ F56-F60 MINI Cooper/S/JCW & 2007+ R55-R61 MINI Cooper/S/JCW
"Click HERE for the MINI Cooper Bremmen Parts Plastics Valve Covers (OEM design) "
Old Jun 14, 2023 | 02:52 PM
  #343
New Union Jack Ziza LED Tail Lights! Gen 1/2/3 MINI Coopers
New Union Jack Style Lights that came from the newest F56 LCI MINIs but made to fit the older MINI Cooper Models and F56-F60 whom did not select that dealer option.
Plug and Play!
2 versions for each generation!
Fits
2002-2008 R50/R52/R53 MINI Cooper/S/JCW (Gen1)
2007-2015 R55-R59 MINI Cooper/S/JCW (Gen2)
2014+ F55/F56/F57 MINI Cooper/S/JCW (Gen3)
Gen1
Gen2
Gen3
"Click HERE for the MINI Cooper Union Jack taillights R50-F57 "
We even have them for the 2017+ F60 MINI Countryman
"Click HERE for the MINI Cooper Union Jack Countryman Taillights "
Old Jul 12, 2023 | 01:23 PM
  #344
Only at ECS Tuning!
New Vaico All weather factory fit tire tread floor mats. Included mat hold down clips.
Protects interior with water holding edge lipped design.
Fits
2007-2015 R56-R59 MINI Cooper/S/JCW (Gen2)
"Click HERE for the MINI Cooper All Weather Tire Tread Design Floor Mats "
Old Jul 21, 2023 | 02:24 PM
  #345
New Lifetime Replacement Program!
Announcing our New Lifetime Replacement Program!
If you need to replace your Qualifying Parts, we make it easy! Simply purchase your replacement order by signing
into your ECS Tuning account to view your order history and click the "Redeem Lifetime Replacement" button next
to the qualifying order to begin! We will automatically create and email a return authorization number ("RMA")
for your qualifying order once the replacement order ships.
"Click HERE for the learn more about the Lifetime Replacement Program "
Old Jul 26, 2023 | 10:35 AM
  #346
Announcing New ECS Adjustable Coilovers Gen 1 & Gen 2 MINIs
Coilover System that provides a sport-tuned, height, damping, and body adjustable suspension!
Our MINI Coilover Line is designed with the daily driver in mind! Our focus was to improve on the performance and aesthetics of your vehicle without forgetting comfort. With 32 levels of available damping and height adjustments tailored to each car, our coilovers are right in that sweet spot of firm and compliant while giving you an aggressive look and vastly improved handling.
**The biggest options are front adjustable Camber Plates = Alignment for track or within factory alignment specs when lowered.
**Adjustable Dampening = Being able to dial in the rear/front dampening (click way out) for a comfortable daily drive (think smoother then factory) or click far inward for a track like response (Because Racecar).
Fits:
Gen 1 MINI R50 R52 R53
R50 MINI Cooper 2002-2006
R52 MINI Cooper Convertible /S/JCW 2005-2008
R53 MINI Cooper S/JCW 2002-2006
"Click HERE for the Gen 1 R50-R53 Coilovers "
Fits
Gen 2 MINI R55 R56 R57 R58 R59
R55 MINI Cooper Clubman /S/JCW 2008-2014
R56 MINI Cooper /S/JCW 2007-2013 (Hardtop/hatch)
R57 MINI Cooper Convertible /S/JCW 2009-2015
R58 MINI Cooper Coupe /S/JCW 2012-2015
R59 MINI Cooper Roadster /S/JCW 2012-2015
"Click HERE for the Gen 2 R55-R59 Coilovers "
Old Aug 4, 2023 | 11:22 AM
  #347
Old Aug 11, 2023 | 10:11 AM
  #348
Easiest Way Ever For You To Shop Overstock!
Click BELOW Link to see all the parts and then call in to make offer!
https://docs.google.com/spreadsheets...gid=1263381345
Old Aug 21, 2023 | 03:34 PM
  #349
Old Sep 7, 2023 | 03:38 PM
  #350
New N12/N16 Metal Valve Covers - RED and Silver
Now fix both PCV and cracked valve cover while upgrading to a high temp aluminum painted valve cover in RED or Silver!!
OEM Design.
Fits 2007+ R55-R61 MINI Cooper (Base NON Turbo)
"Click HERE for the N12/N16 MINI Cooper Bremmen Parts Metal Valve Covers "
"Click HERE for the ALL MINI Cooper Bremmen Parts Metal Valve Covers "
