-   -   :: ECS Tuning :: Your One Stop Shop For MINI Cooper Parts !! (https://minicooperforums.com/forum/general-mini-cooper-talk-30/ecs-tuning-your-one-stop-shop-mini-cooper-parts-6033/)
ECSTuning Sep 25, 2025 10:53 AM
Our brand new R60 MINI Countryman/ R61 MINI Paceman Coilover line was designed with our daily drivers in mind! Our focus was to improve on the performance and look of the suspension, without forgoing any comfort. Like many of the top-tier coilovers, these coilovers feel as smooth and comfortable as a stock setup, while giving you an aggressive look and vastly improved handling, all at a fraction of the price!
Dial in your suspension with 32 way adjustable damping coilovers to improve the Performance, and Style of your MINI!
https://assets.ecstuning.com/product...3857_x800.webp
https://assets.ecstuning.com/product...3878_x800.webp
https://assets.ecstuning.com/product...3876_x800.webp
PERFORMANCE FEATURES
32 levels of rebound damping adjustment
  • Lowering Adjustment of R60 Countryman/R61 Paceman: Stock to 3 1/8" Front drop and Stock" to 2 7/8" Rear drop.
  • R60 Countryman/R61 Pacman Max lift: 1/4" over stock.
Adjustable damping, monotube shocks/struts paired with optimized progressive rate coil springs gives your vehicle road-sticking grip with reduced body roll for exceptional confidence in your vehicle's handling. With your vehicle's new, lower ride height the center of gravity is now moved lower, further improving handling performance
Adjustable front bodies allow you to set the ride height while maintaining correct spring pre-load
Adjustable front and rear bodies allow the shock to operate in the correct valving range, regardless of ride height
Spring Rates: Front is 8kg/mm, Rear is 6kg/mm
PRODUCT DESIGN
Strut and shock bodies finished with a durable gloss black powder coat for good looks and great longevity
Threaded portions are are clear zinc coated for optimum corrosion protection against rain and salt
Coil springs are powder-coated Reflex Silver Metallic finish for durability
Red anodized, billet aluminum lower spring seats with locking collars allow for quick, on the car, adjustability with the included spanner wrenches
Integrated bump stops
For Your MINI R60 Countryman/R61 Paceman 2011-2016
And Free shipping!
"Click HERE for the R60/R61 MINI Countryman/Paceman Coilovers
ECSTuning Oct 2, 2025 03:43 PM
New ECS R53/R52 Catback Performance Exhaust
Lightweight and well-balanced, this exhaust delivers a deep, low-frequency tone for daily driving, while unleashing exciting pops and burbles under spirited throttle.
Engineered with precision and crafted for enthusiasts, our ECS Tuning Cat-Back Exhaust System for the MINI Cooper S and JCW delivers a true blend of performance, aesthetics, and acoustic refinement. Whether you’re carving corners or cruising the highway, this system transforms your MINI’s character while maintaining real-world usability.
From the first drive, the system delivers a distinctly refined but sporty soundtrack. In non-sport mode, it produces a deep, bass-heavy tone that’s civil around town. Switch into sport mode, and the sound comes alive with pops and burbles that add excitement without overwhelming the cabin. Highway drone is kept to a minimum.
~ up to 20lbs lighter then stock!!
You can make the system resonated or non resonated with a quick switch of a mid pipe!!
Developed In-House using FARO ARM laser scanning and SolidWorks 3D CAD to ensure precision fitment and unmatched consistency. 2.5" T304 Stainless Steel Tubing: CNC mandrel bent with a brushed finish and 1.25mm wall thickness for strength, longevity, and flow. Straight-Through "Turbo Style" Muffler: In-house engineered with a perforated core and stainless steel wool packing for aggressive sound under throttle, while maintaining refined tones at cruise. Adjustable Exhaust Tips: Offers 10mm of vertical adjustment for perfect rear valance alignment. Tig-Welded & Back-Purged: Each system is meticulously assembled for long-term durability and a clean, art-like finish.
Fitment:
R52/R53 Cooper S/JCW 2002-2008
Sound Clip!
Install PDF: https://assets.ecstuning.com/static/...llation_R1.pdf
And Free shipping!
https://assets.ecstuning.com/product...3622_x800.webp
https://assets.ecstuning.com/product...4458_x800.webp
https://assets.ecstuning.com/product...3616_x800.webp
"Click HERE for the R53/R52 MINI Cooper S/JCW ECS Tuning Performance Exhaust
ECSTuning Oct 10, 2025 03:49 PM
New MMX Performance MINI Cooper Wheels in 5X112 Fitments!Designed in 18x8 with an ET44 offset, 5x112 bolt pattern and a 66.6 mm center bore, these wheels strike the perfect balance of strength, lightweight performance and style. Available in Black, Gunmetal and Silver, they bring a bold new look to the MINI F-Series whilst delivering the durability and performance you would expect from flow formed construction.
  • Direct bolt on wheels
  • Clears JCW brakes*
  • *Has not been tested on GP3 Brakes or 2020+ Countryman JCW or F54 Clubman JCW brakes as these are larger then stock JCW brakes.
  • 6 Spoke design
  • Motorsport inspired design
Fits
F54-F60 MINI Coopers 2014+
Not tested on F65+ Yet but could fit.
And Free shipping!
https://ecsmedia.ecstuning.com/MINI_...KT12353_01.jpg
https://assets.ecstuning.com/product...4118_x800.webp
https://assets.ecstuning.com/product...4296_x800.webp
https://assets.ecstuning.com/product...4090_x800.webp
"Click HERE for the MMX Performance MINI Cooper Wheels
"Click HERE for the all MMX Performance MINI Cooper Parts
Bremmen Parts - New Parts - Larger Catalog!
New Fuel Filters, Parking Brake Cables, and Actuators!
Bremmen Parts, available at ECS Tuning, offers a wide range of direct-fit replacement parts and Upgrades designed to match OEM specifications at a fraction of the cost. Whether you need body panels, lighting, trim, mirrors, cooling system components, or interior accessories, Bremmen provides reliable, cost-effective solutions without compromising on quality.
https://assets.ecstuning.com/product...5389_x800.webp
Also lifetime replacement!!
And Free shipping!
"Click HERE for the MINI Cooper Bremmen Parts
Rennline Skid Plates
Protection for winter and lowered cars!
Gen 1, Gen 2, and Gen 3 MINI Cooper Fitments!
https://assets.ecstuning.com/product...6207_x800.webp
https://assets.ecstuning.com/product...7953_x800.webp
https://assets.ecstuning.com/product...8255_x800.webp
And Free shipping!
"Click HERE for the MINI Cooper Rennline Skid Plates
ECSTuning Nov 14, 2025 03:41 PM
Crafted from 18-gauge 304 stainless steel, this heat shield delivers superior thermal protection thanks to 304SS’s low thermal conductivity and excellent heat resistance. It effectively deflects and dissipates radiant heat away from your ignition coils and wiring, helping to extend component life and maintain reliable performance.
This also acts a design cover which completes the look of the factory valve cover that seems to be out of place!
Works with aftermarket and OEM factory main valve cover that is plastic or upgraded metal! Like Bremmen Parts!
The shield offers maximum coverage and works seamlessly with both plastic and metal valve covers, utilizing the factory valve cover mounting stud and OEM grommet for a secure, vibration-resistant fit. Its durable brushed finish complements your engine bay while standing up to the harshest heat cycles.
  • 18-gauge 304 Stainless Steel
  • Specifically designed for N14/N18 engines for maximum coverage and heat shielding
  • Works with both plastic and metal valve covers
  • Utilizes the factory mounting stud found on the valve cover and the factory grommet found on the factory engine cover
  • The factory valve cover does not have a front full plastic cover, just a little snap-in cover near the main harness in the front. This small plastic part stays in place when the metal is installed over it.
  • In order to change oil or add oil plate is simply removed with two round-head Allen screws at the bottom.
N14 Engine
https://ci3.googleusercontent.com/me...79282_x800.jpg
https://assets.ecstuning.com/product...2147_x800.webp
N18 Engine
https://ci3.googleusercontent.com/me...70738_x800.jpg
https://ci3.googleusercontent.com/me...13375_x800.jpg
Fitment:
R55-R61 MINI Cooper S/JCW 2007-2016
N14 and N18 Turbo Engines only!
And Free shipping!
"Click HERE for the New ECS Heat Shield Kit
ECSTuning Nov 21, 2025 03:35 PM
Its here, the biggest PRE black friday performance sale of the year! Over 50+ brands total! No one has a larger sale then ECS!
And Free shipping! And Lifetime Replacement*! Price Match Guarantee.
Milltek Sport, Forge Motorsport, Dinan, EBC Brakes (Coupon Code), Bremmen Parts, Clutch Masters, CTS Turbo, KONI, ECS, Ziza, Rennline, M7 Speed, NM Engineering, Bilstein (Coupon Code) Superpro, Whiteline, Alzor, MMX, KONIG, Racing Dynamics, Wagner Tuning, ALTA, FTP Motorsport, Injen, K&N, AEM, MSD, JE Pistons, Wiseco, Tarox Brakes, Bavsound, MOMO, Hengst, Schwaben, URO, URO Premium, Torque Solutions, and PSB! All on sale!
Some select vendors highlighted below, at the very bottom it links to all the sales, see all the pre black friday deals.
NEW ECS Tuning Branded Parts on SALE!
https://ecsmedia.ecstuning.com/MINI_...KT12635_01.jpg
"Click HERE for the MINI Cooper ECS Tuning Sale (ECS Branded Parts)
"Click HERE for the MINI Cooper Milltek Sport Exhaust on Sale
"Click HERE for the MINI Cooper Forge Motorsport on Sale
"Click HERE for the MINI Cooper M7 Speed on Sale
"Click HERE for the MINI Cooper Dinan Parts on Sale
"Click HERE for the MINI Cooper EBC Coupon Code at Checkout "Brakestuff"
"Click HERE for the MINI Cooper Bremmen Parts Deals
"Click HERE for the MINI Cooper Clutch Masters Deals
"Click HERE for ALL MINI Cooper Black Friday Deals
ECSTuning Nov 25, 2025 08:57 AM
Rare Genuine MINI Sale! Ends soon! Dont wait! JCW parts on sale!
Limited Time so Act Fast!!
Majority of the Genuine MINI catalog is on sale. Even ECS Made Genuine MINI Kits!
Most parts have the new lifetime replacement also! If you see these logos:
https://assets.ecstuning.com/static/...eplacement.png
With Free shipping!
https://assets.ecstuning.com/static/...eeshipping.gifFree Shipping
AND
SPIN TO WIN
https://spintowin.ecstuning.com/
https://assets.ecstuning.com/product...1476_x800.webp
https://assets.ecstuning.com/product...1819_x800.webp
https://assets.ecstuning.com/product...1727_x800.webp
https://assets.ecstuning.com/product...2529_x800.webp
"Click HERE for the MINI Cooper Genuine MINI Parts on Sale
ECSTuning Nov 28, 2025 12:44 PM
More Brands added and linked above!
MMX, ALTA, Megan Racing, 3D Design, Konig, JM Turbo Coopers, X Force, CTS Turbo, AFE, Genuine MINI, CRP< Rein, Febi, Elring, VDO, Zimmerman, Bosch, Pentosin, Meyle, Hella, Lemforder, Kimblade, Continental, Mann, King Bearing, AMC, Dorman, Victor Reinz, SKF, Kolbenschmidt, Castrol, Hepu, FAE, Bowa, Burgaflex, and more!
ECSTuning Dec 1, 2025 09:27 AM
Its here, the biggest Cyber Monday performance sale of the year! Over 50+ brands total! No one has a larger sale then ECS!
Some select vendors highlighted below, at the very bottom it links to all the sales, see all the Cyber Monday Deals
https://ecsmedia.ecstuning.com/Cyber...025_Topper.gif
"Click HERE for ALL MINI Cooper Cyber Monday Deals
ECSTuning Dec 12, 2025 12:14 PM
Its here, the Holiday Sale! Over 50+ brands total! No one has a larger sale then ECS!
Dinan, EBC Brakes (Coupon Code), Bremmen Parts, Clutch Masters, CTS Turbo, KONI, ECS, Ziza, Rennline, M7 Speed, NM Engineering, Bilstein (Coupon Code) Solo-werks, Alzor, Racing Dynamics, Wagner Tuning, ALTA, Injen, K&N, AEM, MSD, MOMO, Hengst, Schwaben, URO, URO Premium, and PSB! All on sale!
Some select vendors highlighted below, at the very bottom it links to all the sales, see all the deals.
https://assets.ecstuning.com/static/...600_23103.webp
NEW PARTS RELEASED!!
"Click HERE for the MINI NM Engineering on Sale
"Click HERE for the MINI Cooper Racing Dynamics on Sale
"Click HERE for ALL MINI Cooper Deals
ECSTuning Dec 15, 2025 03:25 PM
New Brand added to the sale.
JM Turbo Coopers - up to 10% off, ends next Monday!
https://www.ecstuning.com/b-jm-turbo...-parts/v-mini/
https://assets.ecstuning.com/product...8605_x800.webp
