Old Jan 14, 2026 | 03:02 PM
  #411
If you're looking to improve the handling of your MINI Cooper Rear Sway Bar this is the best place to start! These cars have more body roll than desired and the stock sway bar doesn't quite do enough for most owners to be satisfied.
Larger diameter sway bars have a higher torsional spring rate which helps resist excessive body roll. By eliminating the excessive body roll and changing the stiffness of the sway bars front to rear, we can improve handling characteristics by reducing understeer and keep the tire in full contact with the ground. By upgrading to the ECS Tuning Solid Sway Bar, you will experience less body roll, and a massive improvement to the handling characteristics of your vehicle, with virtually no sacrifice in ride quality.
Larger diameter than the stock
ECS Red powder coated for great looks and corrosion resistance, comes with ECS Tuning sticker to place on the bar
Polyurethane bushings - reduces flex at mount as compared to OEM rubber
Includes silicone grease for bushing to be applied
Fitment:
Fits: Select R50-F60 MINI Cooper 2002-2024
And Free shipping!
"Click HERE for the New ECS Sway Bars
Old Jan 21, 2026 | 12:08 PM
  #412
For the F5X generation, MINI stepped into a new era by equipping all models with BMWs turbocharged B38/B36 and B48/B46 engines. More boost means more excitement but you would never know with the factory airbox in place. The stock intake keeps things quiet, dulled, and choked off, muting the turbo sounds and holding back the engaging character these engines are capable of delivering.
The ECS Luft-Technik Performance Intake System is designed to maximize efficiency, airflow, and induction sound, enhancing your driving experience while completely transforming your engine bay. This intake unlocks an unparalleled auditory experience by eliminating restrictive factory components, thereby freeing up the induction soundtrack for an exhilarating experience. Let your engine breathe!
MAF (Mass Air Flow Senor) designed for Pre LCI and LCI cars, you use the OVAL inlet for PRE LCI and additional Plate for LCI cars!!
~24% increase in flow over stock!
Install instructions on our site under the "Installation Tab".
Fitment:
Fits:: F54-F57 MINI Cooper /S/JCW 1.5L and 2.0L 2014-2024
And Free shipping!
"Click HERE for the New ECS Air Intake System
Old Jan 30, 2026 | 03:35 PM
  #413
Designed to fix a known weak point for the MINI B3X and B4X engines, this billet aluminum oil filter housing cap is a direct replacement for the factory plastic cap. The OEM piece is infamous for cracks, stripped threads, and rounded hex heads—often failing during routine oil changes and turning basic maintenance into a frustrating, time-consuming repair.
Our precision-machined billet aluminum upgrade eliminates those issues, delivering strength, durability, and consistent fitment you can rely on. An integrated drain plug allows you to drain the filter housing cleanly before removal, reducing spills and mess for a faster, cleaner oil service. It’s a simple, smart upgrade that improves serviceability, reliability, and underhood appearance—exactly the way it should have been from the factory.
Replaces OEM MINI part number 11428575907. MINI 2014-2019
Install Tip** When installing aftermarket or factory filter you will need to replace or install a new O-ring from the plastic 10NM Drain plug on the cap. Our design on the 10NM drain plug only needs the smaller O-ring from that oil change kit.
**When installing aftermarket or factory oil filters you will have to align the filter on the tube inside the oil filter housing then align and tighten down the cap. This forces the plastic tabs on the top of the filter to snap in the tight metal tabs on the inside of the cap.
We even have it paired with our Bremmen Parts Oil filter housing upgrade for the Ultimate Combo!
Fitment:
Fits:: F54-F57 MINI Cooper /S/JCW 1.5L and 2.0L 2014-2019
And Free shipping!
"Click HERE for the New ECS Billet Aluminum Oil Filter Cap
__________________________________________________ _________________
These headlights are designed to resemble the later Gen 3 F60 LCI+ MINI OEM LED Projector headlights, but are for the F60 MINI Cooper Models. Featuring high impact plastic lenses with black housing, these lights use an LED DRL and black exterior LCI+ design.
*Designed for MINIs without factory LED headlights.
Plug-and-play.
**factory halogen headlights do not have headlight washers**.
Features:
  • Manual adjustable leveling on back
  • E-code cutoffs on the projector for left hand drive models; motorized for Hi/Low beam with Bi-LED setup
  • Black matte housing design with chrome and no MINI logo
  • Plug and play
  • Turn signal integration and DRL rings.
Fitment:
Fits:: F60 MINI Countryman ALL4/S/S ALL4 / JCW 1.5L and 2.0L 2017-2020
And Free shipping!
"Click HERE for the New Ziza F60 LED Headlights
"Click HERE for the All New Ziza LED Headlights
Old Feb 3, 2026 | 02:46 PM
  #414
More Genuine MINI Parts have been added! We have worked on the catalog and added more Genuine MINI parts. Correct Catalog per model.
Most parts have the new lifetime replacement also!
With Free shipping!
Free ShippingFree Shipping
"Click HERE for the MINI Cooper Genuine MINI Parts
Want select European Spec MINI parts? Click below.
"Click HERE for the MINI Cooper European Spec Genuine MINI Parts
New Forge Motorsport Electronic DVs. Introducing the Forge Motorsport E-DV for Mini Cooper S, Peugeot 207 & 208, and Citroen DS3 (E-DV); an innovative, British designed and manufactured electronic diverter valve (DV) solution that combines cutting-edge technology with ease of use.
Key Features:
  • Plug and Play Design: The Forge E-DV is 100% plug and play, eliminating the need for remote solenoids or complex vacuum plumbing. This means hassle-free installation and operation for every user.
  • High-Quality Construction: Made from certified aerospace-grade aluminum billet, the E-DV ensures durability and performance.
  • Enhanced Performance: Experience quicker response times and improved throttle responses compared to OEM options. The E-DV is 100% leak-free and designed to avoid triggering engine management light (EML) issues.
  • Hybrid Venting Options: Forge's unique design allows for atmospheric venting without disrupting modern OEM ECU controls, providing flexibility based on your needs.
  • 360° Rotational Flexibility: The valve can be rotated a full 360° upon installation, accommodating tight spaces and nearby components.
  • Durable Technology: Features an integrated electronic pilot valve proven in multiple global motorsport applications, ensuring reliability and performance under pressure.
  • Fully Serviceable: The E-DV is designed for easy maintenance, ensuring longevity and continued performance.
  • No Compressor Surge: Say goodbye to compressor surge issues, allowing for smoother operation.
  • Lifetime Warranty: Forge backs their product with a lifetime guarantee, reflecting their commitment to quality and customer satisfaction.
"Click HERE for the MINI Cooper EV DVs
"Click HERE for the ALL MINI Cooper Forge Motorsport
Old Feb 12, 2026 | 01:34 PM
  #415
New Vitesco HPFPs added!
OEM for less. New MIN factory Supplier!
With Free shipping! & Lifetime Replacement!
"Click HERE for the MINI Cooper Vitesco HPFPs
"Click HERE for the MINI Cooper other branded HPFP
Old Mar 2, 2026 | 11:42 AM
  #416
NM Engineering Sale - Ends this week! Also New Product Added!!
ONLY at ECS Tuning on these select parts!!
And Free shipping!
"Click HERE for the MINI Cooper NM Engineering Sale
M7 Speed - New Product Added
And Free shipping!
"Click HERE for the MINI Cooper M7 Speed New Products
Old Mar 11, 2026 | 03:50 PM
  #417
Finally.... Bremmen Parts Windshield Cowls!
And Free shipping!
Fits 2007- 2015 R55 R56 R57 MINI Cooper, Hardtop, Clubman, and Convertible!
"Click HERE for the MINI Cooper Windshield Cowls
Vitesco Technology
And Free shipping!
- New Name for Schaeffler Group OEM MINI Pump -
- History Lesson: Previous Pump for Genuine MINI were Continental Brand, then Continental created Vitesco and then merged into Schaeffler -
"The Spin-off of Vitesco Technologies was approved by Continental AG's Annual Shareholders' Meeting on April 29, 2021. Vitesco Technologies autonomy enables it to focus entirely on the shift towards electric mobility.
The Vitesco Technologies Group became part of the Schaeffler Group as of October 1, 2024, due to the merger of Vitesco Technologies Group AG into Schaeffler AG."
"Click HERE for the MINI Cooper HPFP Vitesco
Old Today | 10:19 AM
  #418
Final Hours Milltek, Forge, Tarox, and Racechip Sale!
Nov 26, 2021 02:34 PM
Oct 21, 2014 01:17 PM
Feb 24, 2014 07:48 AM
Feb 11, 2014 01:01 PM
Oct 29, 2013 10:09 AM
