ECS Tuning If you're looking to improve the handling of your MINI Cooper Rear Sway Bar this is the best place to start! These cars have more body roll than desired and the stock sway bar doesn't quite do enough for most owners to be satisfied. Larger diameter sway bars have a higher torsional spring rate which helps resist excessive body roll. By eliminating the excessive body roll and changing the stiffness of the sway bars front to rear, we can improve handling characteristics by reducing understeer and keep the tire in full contact with the ground. By upgrading to the ECS Tuning Solid Sway Bar, you will experience less body roll, and a massive improvement to the handling characteristics of your vehicle, with virtually no sacrifice in ride quality. Larger diameter than the stock ECS Red powder coated for great looks and corrosion resistance, comes with ECS Tuning sticker to place on the bar Polyurethane bushings - reduces flex at mount as compared to OEM rubber Includes silicone grease for bushing to be applied https://assets.ecstuning.com/product...3170_x800.webp https://assets.ecstuning.com/product...3173_x800.webp https://assets.ecstuning.com/product...0275_x800.webp https://assets.ecstuning.com/product...0280_x800.webp https://assets.ecstuning.com/product...3172_x800.webp Fitment: Fits: Select R50-F60 MINI Cooper 2002-2024 And Free shipping! "Click HERE for the New ECS Sway Bars |
ECS Tuning For the F5X generation, MINI stepped into a new era by equipping all models with BMWs turbocharged B38/B36 and B48/B46 engines. More boost means more excitement but you would never know with the factory airbox in place. The stock intake keeps things quiet, dulled, and choked off, muting the turbo sounds and holding back the engaging character these engines are capable of delivering. The ECS Luft-Technik Performance Intake System is designed to maximize efficiency, airflow, and induction sound, enhancing your driving experience while completely transforming your engine bay. This intake unlocks an unparalleled auditory experience by eliminating restrictive factory components, thereby freeing up the induction soundtrack for an exhilarating experience. Let your engine breathe! MAF (Mass Air Flow Senor) designed for Pre LCI and LCI cars, you use the OVAL inlet for PRE LCI and additional Plate for LCI cars!! ~24% increase in flow over stock! Install instructions on our site under the "Installation Tab". https://assets.ecstuning.com/product...2425_x800.webp https://assets.ecstuning.com/product...2432_x800.webp https://assets.ecstuning.com/product...2433_x800.webp https://assets.ecstuning.com/product...2436_x800.webp https://assets.ecstuning.com/product...2435_x800.webp Fitment: Fits:: F54-F57 MINI Cooper /S/JCW 1.5L and 2.0L 2014-2024 And Free shipping! "Click HERE for the New ECS Air Intake System |
ECS Tuning Designed to fix a known weak point for the MINI B3X and B4X engines, this billet aluminum oil filter housing cap is a direct replacement for the factory plastic cap. The OEM piece is infamous for cracks, stripped threads, and rounded hex heads—often failing during routine oil changes and turning basic maintenance into a frustrating, time-consuming repair. Our precision-machined billet aluminum upgrade eliminates those issues, delivering strength, durability, and consistent fitment you can rely on. An integrated drain plug allows you to drain the filter housing cleanly before removal, reducing spills and mess for a faster, cleaner oil service. It’s a simple, smart upgrade that improves serviceability, reliability, and underhood appearance—exactly the way it should have been from the factory. Replaces OEM MINI part number 11428575907. MINI 2014-2019 Install Tip** When installing aftermarket or factory filter you will need to replace or install a new O-ring from the plastic 10NM Drain plug on the cap. Our design on the 10NM drain plug only needs the smaller O-ring from that oil change kit. **When installing aftermarket or factory oil filters you will have to align the filter on the tube inside the oil filter housing then align and tighten down the cap. This forces the plastic tabs on the top of the filter to snap in the tight metal tabs on the inside of the cap. We even have it paired with our Bremmen Parts Oil filter housing upgrade for the Ultimate Combo! https://ci3.googleusercontent.com/me...KT13124_01.jpg https://assets.ecstuning.com/product...5519_x800.webp https://assets.ecstuning.com/product...4457_x450.webp https://assets.ecstuning.com/product...4460_x450.webp Fitment: Fits:: F54-F57 MINI Cooper /S/JCW 1.5L and 2.0L 2014-2019 And Free shipping! "Click HERE for the New ECS Billet Aluminum Oil Filter Cap __________________________________________________ _________________ __________________________________________________ _________________ ECS Tuning These headlights are designed to resemble the later Gen 3 F60 LCI+ MINI OEM LED Projector headlights, but are for the F60 MINI Cooper Models. Featuring high impact plastic lenses with black housing, these lights use an LED DRL and black exterior LCI+ design. *Designed for MINIs without factory LED headlights. Plug-and-play. **factory halogen headlights do not have headlight washers**. Features:
https://ci3.googleusercontent.com/me...KT13124_02.jpg https://assets.ecstuning.com/product...2857_x800.webp https://assets.ecstuning.com/product...6799_x800.webp Fitment: Fits:: F60 MINI Countryman ALL4/S/S ALL4 / JCW 1.5L and 2.0L 2017-2020 And Free shipping! "Click HERE for the New Ziza F60 LED Headlights "Click HERE for the All New Ziza LED Headlights |
ECS Tuning More Genuine MINI Parts have been added! We have worked on the catalog and added more Genuine MINI parts. Correct Catalog per model. Most parts have the new lifetime replacement also! With Free shipping! https://assets.ecstuning.com/static/...eeshipping.gifFree Shipping https://ecsmedia.ecstuning.com/MINI_...KT13347_01.jpg https://assets.ecstuning.com/product...1476_x800.webp https://assets.ecstuning.com/product...1819_x800.webp https://assets.ecstuning.com/product...1727_x800.webp https://assets.ecstuning.com/product...2529_x800.webp https://assets.ecstuning.com/product...3843_x800.webp https://assets.ecstuning.com/product...8617_x800.webp "Click HERE for the MINI Cooper Genuine MINI Parts Want select European Spec MINI parts? Click below. "Click HERE for the MINI Cooper European Spec Genuine MINI Parts __________________________________________________ __ __________________________________________________ __ New Forge Motorsport Electronic DVs. Introducing the Forge Motorsport E-DV for Mini Cooper S, Peugeot 207 & 208, and Citroen DS3 (E-DV); an innovative, British designed and manufactured electronic diverter valve (DV) solution that combines cutting-edge technology with ease of use. Key Features:
https://assets.ecstuning.com/product...3248_x800.webp https://assets.ecstuning.com/product...3245_x800.webp "Click HERE for the MINI Cooper EV DVs "Click HERE for the ALL MINI Cooper Forge Motorsport |
ECS Tuning New Vitesco HPFPs added! OEM for less. New MIN factory Supplier! With Free shipping! & Lifetime Replacement! https://assets.ecstuning.com/static/...eeshipping.gifFree Shipping https://ecsmedia.ecstuning.com/Mini_...KT13389_01.gif https://assets.ecstuning.com/product...5538_x800.webp https://assets.ecstuning.com/product...3559_x800.webp "Click HERE for the MINI Cooper Vitesco HPFPs "Click HERE for the MINI Cooper other branded HPFP |
ECS Tuning NM Engineering Sale - Ends this week! Also New Product Added!! Also lifetime replacement!! https://www.ecstuning.com/LifetimeReplacement/ ONLY at ECS Tuning on these select parts!! And Free shipping! https://assets.ecstuning.com/product...8966_x800.webp "Click HERE for the MINI Cooper NM Engineering Sale ------------------------------------------------------------------------------------------------- ------------------------------------------------------------------------------------------------- M7 Speed - New Product Added Also lifetime replacement!! https://www.ecstuning.com/LifetimeReplacement/ And Free shipping! https://assets.ecstuning.com/product...1155_x800.webp "Click HERE for the MINI Cooper M7 Speed New Products |
ECS Tuning Finally.... Bremmen Parts Windshield Cowls! Also lifetime replacement!! https://www.ecstuning.com/LifetimeReplacement/ ONLY at ECS Tuning on these select parts!! And Free shipping! Fits 2007- 2015 R55 R56 R57 MINI Cooper, Hardtop, Clubman, and Convertible! https://ecsmedia.ecstuning.com/New_B...KT13571_01.jpg "Click HERE for the MINI Cooper Windshield Cowls ------------------------------------------------------------------------------------------------- ------------------------------------------------------------------------------------------------- Vitesco Technology Also lifetime replacement!! https://www.ecstuning.com/LifetimeReplacement/ And Free shipping! - New Name for Schaeffler Group OEM MINI Pump - - History Lesson: Previous Pump for Genuine MINI were Continental Brand, then Continental created Vitesco and then merged into Schaeffler - "The Spin-off of Vitesco Technologies was approved by Continental AG's Annual Shareholders' Meeting on April 29, 2021. Vitesco Technologies autonomy enables it to focus entirely on the shift towards electric mobility. The Vitesco Technologies Group became part of the Schaeffler Group as of October 1, 2024, due to the merger of Vitesco Technologies Group AG into Schaeffler AG." https://ecsmedia.ecstuning.com/New_B...KT13571_02.jpg "Click HERE for the MINI Cooper HPFP Vitesco |
Final Hours Milltek, Forge, Tarox, and Racechip Sale!
ECS Tuning Four great and known brands on Sale for the season! Exhaust, Intakes, and Big Brakes! Also lifetime replacement!! https://www.ecstuning.com/LifetimeReplacement/ And Free shipping! https://assets.ecstuning.com/product...91964_x800.jpg https://assets.ecstuning.com/product...9214_x800.webp https://assets.ecstuning.com/product...09880_x800.jpg https://assets.ecstuning.com/product...2026_x800.webp "Click HERE for the MINI Cooper Milltek Sale "Click HERE for the MINI Cooper Forge Motorsport Sale "Click HERE for the MINI Cooper Tarox Brakes Sale "Click HERE for the MINI Cooper Racechips Tuning Box |
| All times are GMT -5. The time now is 05:41 AM. |
