Mini Knights Bridge Bubling Colent in expansion Tank!!! Help?
Hi guys I need some advice,
I've got a Mini Cooper Knightsbridge year 2000 1275cc Mpi engine but converted to spi. Ive got an issue with the radiator expansion tank coolant boiling when I come to a stop , but when I start the engine back, it stops boiling. Temp Gauge never goes above half.
I've check the gauge it works fine, Engine does not overheat how much I drive.
I have cleaned the rad, fan works fine, was not sure if it was the thermostat valve so I got it removed, now I'm running without it. but still the problem remains the same. Is a thermostat valve necessary ? what could be the issue?
Jun 14, 2013 12:21 PM
carriann
Sep 29, 2012 11:44 AM
MINIPartsMass
Sep 27, 2012 11:33 AM
Buzz
Mar 10, 2011 09:59 PM
