Need help!!! Dealer messed me up!
hey hows it goin people this is my first post! i recently went to the deal to get my normal maintenance and they forgot to reset my maintenance miles. does anyone know how to reset the maintenance so i dont have to wait a 2 weeks for the dealer to see my car?
RE: Need help!!! Dealer messed me up!
Hm, I'm not sure how but I know it can be done. I'll try to look it up.
Welcome to the forum. |
Here ya are:
1)Push-hold Trip Button (TB) 2)Turn key to position 1 3)Continue to hold (TB), the number 15A will show to the teft of the milage 4)Release (TB) for 3 sec and then hold (TB) again 5)In about 5-8 sec RST will show in the left corner 6)Release and then hold again "15000" will show, press and release 7)Car is now reset to the 15,000 service - (has completed 10,000 mile service) and will count down from 15,000 or: Press and hold the trip odometer button. Insert car key and turn it to the first position. Watch for the word "RESET" to appear on the Odometer indicator. Release the trip odometer button, then press & hold it again. Wait for the "RESET" message to flash. Release the button, and then press & release (once only) The Service interval is now reset to 10,000 miles |
Confused about turning key - it doesn't turn but just presses in.
Allan |
You dug up an old post on a first gen mini .... Non hockey puck ...I posted the info for the 07+ reset as well
To Reset Service Indicators such as the Oil Service Interval, or the Brake Wear Light, perform the following steps: To enter the service Menu: Insert Key Do not press clutch / brake Press Start button Wait until the Car / revelant Service symbol disappears on the Rev counter display Immediately after the symbol goes out - Press and hold Both buttons on the Rev Counter Continue to hold - the system will run a dash light check Continue to hold Display will then show VIN / Menu, - continue to hold through this until the time Reappears on the display. Now release Only the Right hand Button (trip reset) for about a second, and then press and hold again (whilst still holding the LH button) After another second or 2 the display will show the Front Brake Symbol You Are Now in the Service Menu Use the BC Button (on indicator stalk) to scroll through to the relevant symbol - eg Oil Reset or Rear Brakes To Reset the warning indicator light - Press & Hold the BC Button at the revelant symbol until RESET appears - then press and hold again until the process is complete. Turn Off and On the Ignition again - Warning should now have gone! Good Luck ! |
