problem with run flat tire or indicator?
Hi! New member here with a question......flat tire indicator is on in my 2003 Mini....checked tires and all okay. Anybody have this problem?
RE: problem with run flat tire or indicator?
I believe the 03's use a tire size monitor built into the hub it senses a tire size change , I'm assuming that you checked the tire pressure and not just looked at it ...Check the owners manual for resetting instructions
There is a button under the parking brake that will reset this. Press it in & hold it for a few seconds. Wa-laa! No more indicator light flashing in your face.
Thanks to both of you! Quick response and all is fine now.
| All times are GMT -5. The time now is 04:22 AM. |
