02 Senser
Help! I have an 05 S and it's O2 sensor is on the way out. Really hard start. How tough are they to replace? When I look up sensors on line I see a range of $50 to $400 - any suggestions? Clueless here. :eek: (I have 175,000 miles on Jack Jack)
Vicki |
I'd NOT blindly throw an O2 sensor just cause "it's hard to start"
Does it have a CEL ? Is there any codes ? Describe hard to start ? Might just be a weak/bad battery |
I THOUGHT my '03's o2 sensors were going when a SES light came up....turned out to be a purge valve issue. I WAS going to try and CLEAN the o2 sensors using what the BMW forums suggest: CRC QD Electronic Cleaner. The BMW people SWEAR by the stuff and i did use it on my purge valve to clean it out. So far, so good.
I would start on some other places for hard starts though. Per Bad Venge: battery...spark plugs perhaps? Injectors? Good luck with that. -OG
Originally Posted by JackJack
(Post 11942)
Vicki |
The dealer has informed me it's the knock sensor that's not operating properly. $1050!
| All times are GMT -5. The time now is 05:30 AM. |
