05 Getrag 5spd grinding noise
Old May 26, 2005 | 10:48 PM
1fstmini's Avatar
Default 05 Getrag 5spd grinding noise
Subject - My 05' MINI Cooper w. 5-speed Getrag - Transmission Noise Diagnosis
Complaint - On MINI Cooper R50/R52 vehicles produced from 07/2004 and equipped with 5-speed Getrag transmission, the following customer complaints may be encountered.
1. Grinding noise when the reverse gear is selected.
2. Rattling / grinding noise coming from the transmission area when the engine is at idle during a cold start. The noise disappears when clutch pedal is depressed.
Cause
1. Reverse gear was selected with vehicle still in motion. Reverse gear is not synchronized on G252 transmission. Prior to revers gear selction, vehicle should be stationary in order to insure proper engaement.
2. Under investigation.
Measure 1. Advise customer on the proper revers gear selection procedure ( refer to MINI Owner's Manual, page 56).
Old May 27, 2005 | 01:52 AM
XCM828's Avatar
Default RE: 05 Getrag 5spd grinding noise
Is the reverse gear for the 6-speed synchronized? I haven't ever tried putting it in reverse while I was moving, so I wouldn't know. I've done that a couple of times in my Civic, where the car starts rolling back before I put it in reverse, and when I actually do put it in, I can actually feel the gears start to catch, and then theres a really loud grinding noise. Thank God for synchro's.
riscci Mini
Apr 4, 2010 04:30 PM
1fstmini
Feb 27, 2007 10:59 PM
starr
Feb 23, 2007 06:39 PM
autobahner
Jan 4, 2007 01:45 AM
sherry123
Sep 24, 2006 07:38 PM
