08 R56 oil pressure
Did compression test and cylinder 1 = 143.4. 2= 140.2.
3= 159.5. 4 = 132.8. so all good but ...it's is low but within tolerance. On oil pressure test....started at 40 psi and after 5 minutes dropped to 20 psi then 15 psi..... Minimum as far as specs is 20 psi.... I already replaced the oil pump, twice due to oil light coming on...so...what's causing this drop in oil pressure? I need some feedback...please? |
| All times are GMT -5. The time now is 07:21 AM. |
