2007 mini cooper clubman performance flat spot, lacking power, engine noise
Hi Please HELP,
2007 Cooper Clubman has started to show a flat spot in performance at around 2500rpm, when you floor it the power seems to lack but when accelerating half way there doesn't seem to be a problem, I have also noticed that the running sound on idle does not sound as it normally would. I drive a fairly hilly route to work daily and with the lack of power have had to shift down on hills that would normally not be a problem and the lack of performance is making overtaking extremely difficult. Recently taken to a local garage and had a computer diagnostic check ran on the vehicle and there are no faults showing and from a quick check it isn't apparent what the issue is. Local Mini Dealer wants to charge £110 for the first hour of diagnostics and would really be better to avoid this at this stage. Please help guys. Thanks Dean |
| All times are GMT -5. The time now is 06:15 AM. |
