2010 Cooper Electrical Issues HELP!
Old Jul 21, 2015 | 09:50 AM
WalterD's Avatar
Default 2010 Cooper Electrical Issues HELP!
Yesterday I went to start my 2010 cooper and the headlights came on without me turning them on, and they won't turn off; however, the big issue is that the following are not working:
Turn Signals
Cabin Light
Power Windows
Hazard Lights
I hope that it is only a fuse issue, but I do not know which fuse it might be or if there is a larger electrical issue that I need to go to the dealer for.
Any help is much appreciated
Old Aug 16, 2015 | 04:21 PM
Powershift's Avatar
I would start with trying to unplug the battery for ~10 minutes. I may be here too late though...
Old Jan 20, 2017 | 08:37 PM
truches's Avatar
do you find your problem. I have the same issue with 2010 r54
Old Feb 7, 2017 | 02:22 PM
brttwhln's Avatar
Did anyone find out the issue? Just happened with mine.
Thanks!
Old Feb 8, 2017 | 11:59 AM
PelicanParts.com's Avatar
Thanks!
Plug into your DME and check all modules for fault codes. Test your battery. What year and model MINI do you have?
Old Mar 18, 2017 | 12:57 PM
Vix's Avatar
Vix
Same thing here, battery died. Replaced bat and have no turn signals, windows, fog lights, high beams, interior lights. Anyone have ideas of what's up. Btw, mine is a 2011 S. Thanks
Old Mar 20, 2017 | 10:21 AM
Review this article: MINI Cooper R56 Battery and Connection Notes Replacement (2007-2011) | Pelican Parts DIY Maintenance Article. Make sure you installed everything correctly. Not that this would cause your issue, but make sure if you have an IBS unit that you register the battery. Let me know if everything looks right after you review that article.
Old Mar 20, 2017 | 07:05 PM
  #8
Vix's Avatar
Vix
Don't have IBS system, from what I've been able to find out so far is that it's a faulty FRM. I think that's what it's called, aka footwell control module. Hope not, as that sounds like it's gonna be pretty expensive. Thanks in advance.
Old Mar 24, 2017 | 05:48 PM
  #9
Vix's Avatar
Vix
Anybody have thoughts on this. I know I'm not the only one with this issue. Appreciate any help before I take it to a dealer.
Old Apr 14, 2017 | 09:08 PM
  #10
Ashraf Hijazi's Avatar
Default Same thing happened with me
Hi, same thing just happened with it happened after installing that bov adapter thing, any updates?
