-   -   Airbag light won't go off (https://minicooperforums.com/forum/general-tech-8/airbag-light-wont-go-off-4756/)
lolo1964 Aug 14, 2011 05:08 PM
I took my 2002 mini to the local car wash and had them detail it and give it a good waxing. When I got in it, after they were finished, the airbag light didn't turn off. It's been on ever since. Also, I have to pull on the door handle 2-3 times before the doors will unlock, even when the car is turned off. Is there any sort of "switch" they might have "flipped" ?
bad venge Aug 14, 2011 09:33 PM
they might have unplugged the seat airbags when sweeping the carpets...
unsure on the door handle...
lolo1964 Aug 15, 2011 01:40 PM
How would I plug the seat airbags back in?
bad venge Aug 15, 2011 03:47 PM
you'd have to see if they did unplug the connectors underneath the seat if they did then you will have to take it in to the dealer to have the computer reset
you can unplug them with the key off , but if you turn the kry on with them unplugged or plug them in with the ignition on the light is latched on
lolo1964 Aug 15, 2011 10:41 PM
Oh wow. That sucks. The closest MINI dealer to me is 120 miles away! But thank you for your advice. It's much appreciated :)
