alternator seems to lock up
Old Sep 17, 2009 | 07:55 PM
richwn13's Avatar
Default alternator seems to lock up
I have an '05 Cooper S. It runs fine when cool, but once warmed up the alternator locked up. The belt was turning but not the alternator. OK easy fix. Replaced the alternator; new one does exactly the same thing. Any ideas? By the way, new to the forum.
Thanks, Rich
Old Sep 20, 2009 | 04:38 AM
FLMINI-Mech's Avatar
Rich,
a few things come to mind. Double check to make sure that the Alternator is infact not turning, I would remove the belt again and then turn each belt driven accessory by hand, and make sure none are seizing. I would also check and make sure that the belt tensioner is applying proper pressure to the belt. I would also visually inspect the pulley on the crankshaft as they tend to seperate and cause problems.
Its possible you had a defective replacement alternator (especially if its a rebuild), but its much more likely that there is another problem.
Old May 23, 2012 | 11:57 AM
PelicanParts.com's Avatar
Old thread but for anyone considering replacing their alternator: Pelican Technical Article: MINI Cooper - Alternator Replacement
James Hamilton
Mar 3, 2015 06:20 AM
cossie
Aug 21, 2014 01:02 AM
Aug 20, 2013 07:26 PM
RSpi
Apr 3, 2013 10:00 PM
Coopermini
Aug 18, 2008 08:40 PM
