-   -   ambient air temp. problem (https://minicooperforums.com/forum/general-tech-8/ambient-air-temp-problem-815/)
minuteman 01-24-2008 02:00 PM
I have a 2003 mini reads -40 on outside temp, replaced temp sensor, no help, reads "0" ohms on digitial meter from signal wire to ground? looking for ground on wire but not found. anyone have this problem? What sould the ohm reading be from signal wire to ground, this is with the sensor out of the socket.
scuba 01-28-2012 03:00 PM
I have the exact same problem
I will let you know if I find a fix
