ASC sign keeps lighting, what could be wrng?
Hi, Im a new member to this forum. I drive a r50 mini cooper 02'.When i drive for a while, The ASC lights gets turned automatically on and cant be turned off. Wht could be the issue?:cool: |
ASC light
from my past experience there is 2 things that might have happened
1) the ASC cable is ripped 2) you could have gone into a pothole, my frineds did that to their BMW 3-series coupe their traction light went on and off your best bet is to go to a mini cooper dealer and tell them that ur ASC light wont go away hopefully the mini u got still has warrenty |
Thnks ..i guess i better tak my bbaby to the dealer!
Also check that the tires are properly inflated ... A low tire can make it sense wrong
Your ABS harness connector plug (pin contacts) have corrosion wiggle the harness and cycle the ignition if it works --- clean corrosion in pin connector plug/ socket warning do not pry on female side pins, if they widen they won't contact properly male pin contacts.
If it does not work: Your ABS module has internal damage and will need repair/rebuild/and or replaced which needs software and aligning |
