Blew out spark plug sleeve
Old Dec 28, 2011 | 05:08 PM
hawki's Avatar
Default Blew out spark plug sleeve
Hi Everyone,
My car started sounding like a John Deer tractor as I pulled into the garage the other day.
I opened the hood and there was a spark plug with a small threaded sleeve around it laying on top of the valve cover.
Is there a previous post that anyone knows about that talks about replacing this - do I have to pull the head, special tools... any advice ?
thanks
hawki
(JD)
Old Dec 29, 2011 | 07:49 PM
It sounds like someone stripped the head and installed a helicoil thread repair kit
Old Dec 30, 2011 | 11:40 AM
hawki's Avatar
Can a repair be made "after" a helicoil repair has failed without pulling the head?
Old Dec 30, 2011 | 02:57 PM
You MIGHT be able to get an oversized one take the plug with sleeve into an autoparts store and see if they have a kit /bigger then the one currently the kit includes a tap kit and a threading tool to install the coil
I've heard it done with head on
Old Dec 31, 2011 | 12:09 PM
hawki's Avatar
Thanks I will look around and see. Others have mentioned something called a time sert. Looks to be like $300 for the kit... wow. But they say it does a better repair especially when a helicoil repair has failed. thanks again for the response.
Aug 3, 2016 12:08 PM
BroKennMini
Jun 5, 2014 10:44 PM
Jun 24, 2013 06:43 PM
Jun 13, 2013 11:17 AM
Sparkplugs.com
Dec 1, 2006 04:11 PM
