Coolant temp sensor?
If anyone has experience with this problem, insight is appreciated.
I have a 2003 Mini Cooper s. I have a engine service light on. I've reset it. Cleared the code, changed the thermostat, flushed and filled... The light and code keep coming back. Any suggestions what to try next? Code: P0128 Coolant Thermostat (coolant temperature below thermostat regulating temperature). |
Hello David! What thermostat did you install?
Thermostat
Originally Posted by PelicanParts.com
(Post 20928)
Originally Posted by David L
(Post 20930)
Can't say I'm entirely sure. I ordered it, I think online, it was supposed to be oem. That I'm sure of. It was a few months ago. Do you think it's possible that it was not oem and that's what is causing the problem?
Check out these links here: http://www.obd-codes.com/p0128 P0128 - Coolant Thermostat Malfunction - OBDII Engine Light Trouble Code | AutoCodes.com |
(Post 20921)
| All times are GMT -5. The time now is 09:54 AM. |
