Cooper 2002 Central Locking!
Hi,
Got my 2002 Cooper two days ago and happy! But, I cannot open the doors with the remote key but can lock them!! Have to put key in lock to unlock but central locks fine? HEard there is a reset you can do? An ideas/ |
First I'd check the lock/unlock on the remote ... My Autozone/Advanced has a "tester" you activate both buttons and see if there is an output , no output in the one the remote has a trouble ... Might be a dirty switch , even a weak battery
If there is an output for each then the reciever may have a trouble , I'm not aware of a reset other then disconnecting the battery and reconnecting it , any further then that will need a dealer to connecct to the bus to check activity |
| All times are GMT -5. The time now is 02:28 AM. |
