-   -   Creaking noises (https://minicooperforums.com/forum/general-tech-8/creaking-noises-1366/)
JBRadMini Sep 11, 2008 04:47 PM
Creaking noises
Anybody experience any creaking noises coming from their steering wheel when you make a u turn?
My 02 has some that only happen when I turn the wheel a lot, not when I'm changing lanes.
I heard from some other forum that it was a design defect and Mini would not fix it.
has anybody else heard of this or have this creaking coming from their steering wheel?
JBRadMini Sep 12, 2008 10:53 PM
RE: Creaking noises
I found this looking around the net for an answer to my noise. Some people have gone as far as replacing the steering column but it's not needed as long as you don't have play in your shaft.
I'm going to do the lubrication on mine and see if it clears it up.
I have no play and it only sounds like the nylon bushing is dry and creaky.
check out the link for info on how to fix yours if you have the dreaded steering wheel click on the early Mini's.
http://www.mini2.com/forum/faults-fi...ng-column.html
JBRadMini Sep 12, 2008 11:10 PM
RE: Creaking noises
email me for the link if you need it. Apparently the forum doesn't allow to show the link.
bad venge Sep 13, 2008 04:44 PM
RE: Creaking noises
not allowed to link to other mini boards ....
Adam Sep 14, 2008 04:08 PM
RE: Creaking noises
ORIGINAL: bad venge
bingo-bango.
