-   -   drain/refill ATF (https://minicooperforums.com/forum/general-tech-8/drain-refill-atf-858/)
socko Feb 20, 2008 08:17 AM
drain/refill ATF
Does anyone know how much automatic transmission fluid comes out when you drain it (without flush)?
In other words, how much do I need to do a drain and refill?
cooperr5053 Feb 27, 2008 06:32 PM
RE: drain/refill ATF
It takes like 5 liters of special ATF for the CVT that you can get at the dealer. But you need a special tool to put it in.
socko Feb 28, 2008 09:45 AM
I'm aware that you must use the ATF supplied only by MINI dealers, and I believe that the fluid capacity is 4.5 litres, but when you just do a drain you won't get all of the fluid out, probably more like one-half, but I would like to know for sure before start. By the way, my dealer wanted $22/litre for the stuff but I called several dealers and found it for about half of that from a dealer in Cincinatti, OH.
