| mjmini |
Apr 11, 2010 08:48 PM |
engine fan
I have a 2002 mini cooper. In the last 3 years, the fan on my engine continues to run long after the engine is turned off. The first repair required a relay to be replaced. The 2nd repair had us removing the front bumper and replacing a high relay. Now, 2 years later we are experiencing the same problem. This time we had to disconnect the battery because the fan would not stop even when the fuse was removed.:mad: Has anyone else experienced this and found a solution that does not require a $400 repair each year??
