Fog lights
Old Aug 9, 2008 | 12:06 AM
smitty's Avatar
Default Fog lights
I just ordered my 08 MCS the other day, and cant wait for it to get in. One thing I was curious about, though, is that most cars have their fog lights turn off when the high-beams go on. I was wondering if Coopers are the same way, and if so, if theres a way to re-code, or re-wire the lights so that once enabled, they stay on for high and low-beam.
Old Aug 9, 2008 | 04:06 PM
MINIofANNAPOLIS's Avatar
Default RE: Fog lights
on the coopers the fog lights only come on when the high beams are on. that is how we wire the lights. i am sure you can wire them anyway you want.
Old Aug 9, 2008 | 05:12 PM
clnconcpts's Avatar
The fog lights go off when high beams are turned on.The Driving lights can only be used when high beams are turn on.According to the vehicle code,this is the only way it can work to remain legal
Old Aug 9, 2008 | 05:21 PM
LAAutoAl's Avatar
Federal laws allow that the fog lights come on only when the low beam lights are on. Allowing them to come on with the high beams would blinding the on coming drivers. The fog lights are usually controlled by a relay. When the the high beams come on it automatically shuts the fog light relay off. There is also a possibility that all the lights are controlled by one control unit. Knowing the parent company BMW, that's the way they do it. They try to make things as complicated as possible. It could be done, but it would take a lot of work.
Old Aug 9, 2008 | 10:38 PM
smitty's Avatar
That's about what I thought. Thanks for the info!
Old Aug 18, 2008 | 08:38 PM
naturallybuilt's Avatar
Is there a way to have the front and rear fog lamps automatically come on as do the daytime running lights? I like the look and increased visibility of the fogs, but it seems silly to flip two switches every time I get into the car. Thanks.
Mar 10, 2015 04:50 PM
mini lfstyle
Nov 18, 2014 07:19 AM
Jul 10, 2014 12:57 PM
X68monkeyx
Jan 17, 2012 05:58 PM
kayaklaw
Jan 21, 2010 04:27 PM
