Front cigarette lighter not working
Old Jan 4, 2018 | 05:43 AM
brightonminicooper's Avatar
Exclamation Front cigarette lighter not working
Hi All
My Front cigarette lighter isn't working, which is a pain as I need to use it for phone charging/ipod.
I've looked online, and there are a few suggestions with pics, and the fuse diagrams shown have a picture of a "cigarette" so easily identifiable; mine however, has not picture of a cigarette, so I'm at a loss as to what fuse im looking for to check, and replace if needed. Any advice please??
**** I have located a previous thread which mentioned could be F44 fuse; I have replaced this and still nothing :-(
Here's a pic of mine
Last edited by brightonminicooper; Jan 4, 2018 at 06:13 AM. Reason: further investigation
Old May 4, 2018 | 07:36 AM
thirsty_camel's Avatar
I have exactly the same problem, I've checked fuse #44 as directed by various other sites etc and nothing, check inside the connector as well and nothing I can which would stop it from working, anyone any ideas ?
Old May 15, 2018 | 05:21 AM
Skint's Avatar
I also have this problem and keep checking this thread but no one seems to have an answer.
Old Oct 22, 2018 | 09:22 PM
driver8v2's Avatar
I too have this exact same set up on my 2012 Mini Cooper...need to positively identify the lighter/cigarette fuse. The manual is of no help whatsoever.
Old Oct 29, 2018 | 12:45 PM
Minihartstein's Avatar
Default Fuse 2012 Mini Cooper 10th Anniversary
my cigarette lighter was not working and fuse cover was the same as above. When I checked my fuse panel I noticed I was missing fuse 38 and installed a 15amp fuse in and my cigarette lighter began working. I also noticed I had a 15amp fuse in spot F37 that shows its unused on the fuse cover and pulled it to check the fuse it was good maybe been a bad connection there before pulling fuse and reinstalling it. I did that before putting a fuse in F38 Hope this help. You can tell if a fuse goes some place if it has the holder in both slots for the fuse blade.
Old Jul 4, 2019 | 10:17 AM
Denise Cleary's Avatar
On the 67 Mini, throw away the stupid diagram that bears no relation to the fuse board. It is a yellow 20 amp on the left hand side of the fuse board, 3 or 4 down. Hope this helps.
Old Oct 28, 2019 | 01:55 PM
Shana Jones's Avatar
Default Thank you!
On my 2013 mini hatch it is also a yellow 20 amp F44 on the fuse board, 5 down on the right.
Old Oct 31, 2019 | 07:55 AM
  #8
Lindsay Kitchin's Avatar
Default F44 20Amp is the cigarette lighter x
Originally Posted by brightonminicooper
Hi All
f44 20Amp is cigarette lighter or phone charging x
Old Dec 4, 2019 | 09:19 AM
  #9
Georgiagyrl64's Avatar
Default 2018 Countryman All4 Lighter Not Workin
Hello all,
I have a 2018 countryman All4 and I accidentally blew the fuse in my front cigarette lighter. I located the fuse box in the glove compartment, however, I can't figure out which fuse controls the lighter. Can someone help???
Fuse box schematic
Old Dec 14, 2019 | 01:54 PM
  #10
Daveman1977's Avatar
Just shorted out my cig lighter and #44 was definitely the right fuse.
