-   -   having problems (https://minicooperforums.com/forum/general-tech-8/having-problems-648/)
minihusband Oct 22, 2007 10:55 PM
having problems
I'm hearing a strange kind of creeking noise when I turn my sterring wheel, how do I make it go away?
momini Jan 21, 2008 03:46 PM
RE: having problems
creeking like mmmm tick tick tick? if yes u have a bad axle boot, and eventually the axle will snap, and u car wont be able to move.
minis are fwd right? lolz
Indibluemini Oct 13, 2009 05:36 PM
This creaking usually comes from the strut bearings which can be seen under the bonnet...
Look for the little black cap on the shock tower and pull it up and off, you will find the end of the strut and a nut, just under these there are some bearings mounted in rubber which tend to creak on lower mileage cars, mine did for about 40K
bad venge Oct 13, 2009 07:34 PM
Also if it's low on power steering fluid it can creek when turned
